That was stated earlier: no.Am I understanding that the problem was the material in the tab, nut and quick connectors at binding post???
If this is the case, does the problem exist for people who chose the SpeakOn option?
The original quick connectors are not affected (they were always non magnetic). The only reason they need replacing is to fit the new size of the new tabs.Am I understanding that the problem was the material in the tab, nut and quick connectors at binding post???
The only reason [quick connectors] need replacing is to fit the new size of the new tabs.
A)I suspected that much. Repair would be much easier if new tabs fit.
a) Couldn't source new brass tabs in matching size?
b) Discovered they were not a match after having ordered them?
c) Had to order these specific tabs to assure they are non-ferrous to solve the original broblem?
Nice job. Those instructions are clear enough that even I can follow them.Attached is a quick DIY guide for those who will be replacing the necessary hardware themselves from me
Any idea when the ASR review might be updated for Buckeye Purifi measurements?
Only @amirm knows at this point. He did mention that he is under pressure for more time sensitive reviews.
I tested and posted results here: https://www.audiosciencereview.com/...plifier-performance.38701/page-3#post-1499591
Shortly thereafter, it shipped to Amir.
While I understand that Rick's test setup does not have the same level of resolution as Amir's - is that correct, Rick? - it the before and after results with ferrous vs non-ferrous tabs seem pretty clear cut. I will be very surprised if Amir's tests show significantly different results than Rick's for this type of thing.
The contrast in value for money couldn’t be more stark! Congratulations to Dylan in analysing and fixing such a subtle defect. Surely this range of amplifiers should be considered by anyone in N America investing in top notch amplification.Yes, I can see how the JPS $1,000 USB cable and $800 XLR cable reviews might take a front seat to the Buckeye Purifi amp measurement update. I needed something to rate as a total waste of money.
Rotf!It wasn't until a few weeks ago that I found out there are even "audiophile" grade fuses. Someone reached out to me asking for the fuse size I use as they wanted to replace with an audio grade fuse (which was I think around $50-70). For a simple 5x20mm fuse. And that was, as they said, on the cheaper/budget side.
Then I went down a rabbit hole and found there are fuses in the hundreds and thousands. And the reviews for them are....interesting. Like cable reviews but even more baffling.
So, if anyone wants Amir to test a Buckeye Amp with a $100 fuse...
I have tried swaying people away from the unnecessary even before being an audio business owner. But the confirmation bias of spending 100x as much on something as simple as a fuse will usually win out over objective reasoning/reviews.Rotf!
All these items crack me up. I’ve seen not just audiophile wall outlets, but special cover plates, too! Guess it doesn’t matter about the standard old Romex in the wall…
Unless it does and they run new audiophile grade cable to an audiophile grade Service Panel!!!
Yup. They exist. And you can pay to have a dedicated power line installed to your home…
I wonder about those pesky meters, though. We may have to send those to Amir for testing and see how clean the signal is.
Wait.... you mean to tell me Buckeye doesn't employ audiophile-grade fuses? Sure, my system has never sounded this good, but this I cannot abide. Please issue an RMA. I'm going back to Emotiva.It wasn't until a few weeks ago that I found out there are even "audiophile" grade fuses. Someone reached out to me asking for the fuse size I use as they wanted to replace with an audio grade fuse (which was I think around $50-70). For a simple 5x20mm fuse. And that was, as they said, on the cheaper/budget side.
