Buckeye Amps: Purifi 1ET6525SA (the successor to the 1ET400A)
From the results of my testing, it can be seen that when 1ET400A is turned on, there is sometimes a popping sound in the high-frequency part, which is very low and not always present. 1ET7040A also has it, but the impact sound is changed to the low-frequency part. 1ET6525 and 1ET9040 have not found any popping sound at the moment, but for these two models, if they are turned on at a high input signal volume, they may not start and will repeatedly flash twice before starting. At this time, there will be a popping sound and they will work normally again.
All models are DC coupled. If there is DC input into the amplifier in the front stage, even if it is very small, it will repeatedly start, and there will be a loud popping sound at this time.
If there is a popping sound every time the power is turned on or off, it may be because your soft start settings are not done properly.
Thanks for this great post.
Regards, Edi
Dylan (or anybody actually), which size spade lugs will fit the binding posts on my new 2ch 1ET6525SA amp from you? I'm trying to choose between the 6.3mm, 7mm, and 9.2mm from Blue Jeans Cable.
Yes! My "squelching" amps have both been Adcoms too: a GFA-535 and then a GFA-5400. I sold them both a couple of years ago, but they were rock-solid dependable for many years. The lack of built-in speaker protection, though... never was an issue for me fortunately, but still, I probably wouldn't buy such an amp again at this stage in my life when the passive speakers I'd use with such an amp would be a good deal more expensive than what I could afford when I was younger.
Still, I have a soft spot for those old Adcoms. :)
I have a GFA-555 that has been unused in the attic for 10 years that I need to part with (first amp I ever purchased, kinda sentimental). Power on/off pops were a non issue for me: within a couple of months the contacts of the power switch welded themselves closed, I assume from large inrush current. The dealer replaced the power switch, and a couple of months later it welded itself closed again. I accepted as normal that it would be permanently On. So normally no pops.
But on the rare occasion I had to unplug it, or the power went out, there were pops. :-)
But on the rare occasion I had to unplug it, or the power went out, there pops. :-)
Yes, those power switches were something!
When is this recommended over the NCx500?
...I use a rebuilt ABE-515 power conditioner to turn my Adcom GFA 5500 on and off...I never touch the power switch...have not had to rebuild the GFA 5500...
...I will likely be looking at one of these buckeye amps to replace it someday...
I gravitated toward the Purifi module based on reviews and comments on this forum, can’t speak about the ncx500. I am completely satisfied.
Is 1 Hypex SMPS1200A400 enough to drive 3 1ET6525SAs to full power? I'm considering buying the 3-channel Buckeye which uses 1 of that power supply.
My FL and FR speakers are the Dynaudio Emit 50 towers (4 ohms)
My centre speaker is a Monolith by Monoprice THX-365C (4 ohms)
The amp would be fed by the pre-outs of a Denon AVR-X3600H.
I would call Dylan at Buckeye directly.
Not for all 3ch into the 2ohm rating. The SMPS1200 has a peak rating of 1350w so if you were to drive all three channels into max power for a 2ohm load you'd be losing about 50-75w per channel. For a 4ohm load into all three channels simultaneously at full power it would be close but there would still be some power loss per channel.
But luckily, consumer content (even at reference levels) does not tax an amp like benchtop testing does so there will be no issues.
Thanks. Would it be okay to put my centre speaker on top of the 3ch amp?
Edit: Just realised that's where the vent holes are so it's probably not something I should do.
I really admire Bruno Putzeys—he’s one of the key minds behind both the Hypex NCore technology (like the NCx series) and the Purifi Eigentakt amplifier modules. His work consistently pushes distortion and noise to incredibly low levels, which is exactly why I love how my Purifi setup sounds.
;)Had to jump in.. I recently started looking into a potential issue I may have drifted into and become aware of via.. the opposite direction.. A GFA 555 that's been on [steady] now maybe some fifteen years. Yeah. So.. I've been out looking for best 'alternatives.
When clipping, the LED will change to Orange. The duration and "blinking" would be dependent on the clipping (if it is a continuous clip, LED would stay lit orange...but it is transient events it would appear blinking).
Error is Red LED color and can be cleared (if it is not a "mortal" fault but something like high temp or power loss) by turning off and on again
Just fyi, this information is no longer accurate. To my understanding, the current Purifi 1ET6525SA builds no longer have a clipping indicator.
The led now has only two states, blue (normal) or red (protection mode). I noticed this was the case with my build and thought maybe mine was defective, but Dylan confirmed this is how they work now. Apparently the new Purifi modules do not provide clipping indication. Seems odd.
So the only way to tell if you are driving your amp too hard is if it shuts down. I'm a little disappointed to learn this since I was expecting the indicator to be 3-state and to blink orange occasionally if it was starting to clip. It does still list both clipping and error indications as features on the website, but I guess this is outdated.
  • Clipping Indication (via front power LED)
  • Error Indication (via front power LED)
Apologies as I thought I had sent a follow-up email to you this morning (I assume you are the one who emailed me with this exact question).
The Purifi builds do still have clipping indication (it is the NCx500 builds that do not, I had gotten them mixed up when replying on the go).
I just received and set up one of these Buckeye Purifi 1ET6525SA Stereo amps last night, and tested it with both Ascend Sierra LX speakers and Ascend ELX Ribbon speakers. It is a spectacular little amp. As I turn the volume up it just keeps getting louder, and louder, and louder without a hint of distortion. It sounded a little bright at first, but I am confident that is because the amp I was using previously sounded very congested at the high end as the volume got higher, while the Buckeye stays extremely clean and delineated, so I am hearing the higher frequencies more clearly at high volumes. The low end is equally clean and persuasive. This is an excellent implementation of the Purifi modules in a tidy and neat box, with nothing getting in the way. Very impressive piece of kit.
Hi Dylan, yes, that was me. Based on this encouraging news I tried again today to see if I could get the clipping indicator to work on my Purifi 6525 and I could not. As I turn the input up, the amp eventually just shuts down. I cannot seem to find an input level where the amp indicates clipping without shutting down.
It sounds great, and does achieve the rated output power, but just does not seem to have a functioning clipping indicator.
Have you ever tested this feature to see if you could get the led to blink or show orange?
EDIT: I also checked it out in my lab and I can see clipping on the output (jagged sinusoid peaks on scope) as it approaches the rated max power, but still there is no clip indicator activity. Any further increase just shuts it down.
When we test on our end, yes it does clip (Orange LED).
Reactions: Rit
