- Joined
- May 28, 2020
- Messages
- 2,564
- Likes
- 10,644
- Thread Starter
- #661
Purifi finally gave an ETA date of Nov. 9th@Buckeye Amps You had mentioned a mid October launch of the 1ET6525SA?
Thanks
Thanks
Of course, totally understand but did you ever send your 1ET7040SA v2 amp to Amir for review, would have been great to see the measurements?Most likely not planning on a 2ch 7040 anymore, no.
Actually no, it just never came up/a customer never requested their unit to be sent in.Of course, totally understand but did you ever send your 1ET7040SA v2 amp to Amir for review, would have been great to see the measurements?
Between those two modules, no audible difference. We offer both so people can have choices that may come down to something as simple as wanting to stick with Hypex to pair with other Hypex multichannel amplifiers.Hello,
Can you hear a difference between the Purifi 1ET6525SA and the Hypex NCx500 amplifier? If no why sell 3 modules?
What is the biggest difference explained in normal language between the modules?
Thanks.
Each module is QC marked/verified from Purifi (I have never inquired about their actual QC process, however). And then each amp is tested by us before shipping out.Curious to know if you can share. What is the quality control process from Purifi, and Buckeye? Is Purifi testing 100% of modules or batch testing? Is the testing manual or automated? Is Buckeye testing 100% of amps, or batch testing?
| Max Continuous Power* | 350 watts |
| Max Short Term Peak Power* | 500 watts |
I am going out on a limb and assuming that a 2 channel Hypex NCx500, Monoblock Hypex NCx500, 2 channel 1ET6525SA, monoblock 1ET6525SA will be similiar in terms of power and clarity but how does the above compare to a monoblock 1ET9040BA or monoblock NC2K?Most likely not. With the 9040BA monoblock, there isn't much motivation to offer the 6525SA as a monoblock, especially since the outgoing 400A monoblock configuration was not very popular.
The 2ch configuration is the perfect sweet spot instead of a pair of monoblocks.
Has this happened yet and what are your thoughts? I'm about to pull the trigger for my X4800 setupMy new 3 channel 1ET6525SA Buckeye amp for my theater just showed up! It'll be hanging off a Denon X4800H ...
Yes, it happened!Has this happened yet and what are your thoughts? I'm about to pull the trigger for my X4800 setup.
Yes, it happened!
I haven't ran a re-calibration yet due to time, so instead I did a quick and crude levels adjustment by running REW sweeps. With the amp on high-gain, I had to boost the 3 channels about 4.5 dB to get the same levels in my sweeps at the MLP as the on-board Denon amps.
1. No, I did not disconnect them, yet. I noticed during my original setup of the Denon that if I changed anything in the speaker layout config, it would invalidate the Dirac calibration and it gets cleared out. I noticed this when I changed something else (maybe sub setup or something), and from there I just assumed it applies to anything in that menu, including switching the preout/speaker toggle as well. I don't know this for a fact, so I don't want to flip that switch until it is also a convenient time to re-calibrate anyway. When that happens, I'll drop back in here and report the effect on levels.Great, thanks for the update. Couple of points if not aware already:
1) Did you disconnect the Denon built-in amps? Its been a LONG time since I read the x4800 reviews here, but IIRC preamp out gain is higher/cleaner with them disconnected.
2) For level adjust, I personally would use the built in test tones (or something like the Spears test DVD, etc.). They are bandwidth limited to freq's where our ears are most sensitive to level.
