With a 26.5dB gain the Purifi amp works fine with the Denon 4700 using the Monolith XLR to RCA cables. Audyssey increases the levels +2 dB to match the internal AVR amps. Adding RCA plugs to the Purifi build adds cost for everyone while most will use it with XLR DAC's and Pre-amps. There are many different brands of XLR to RCA cables available that work for this purpose. The key will be having a 26dB gain stage on the Purifi if you plan to use it with the Denon 3700/4700/6700.
Amazon.com: 3 Foot - RCA to XLR (Male) Cable Pair - Canare L-4E6S Star-Quad Audio Interconnect Cable & Neutrik-Rean NYS RCA & Neutrik Male XLR Gold Plugs - Custom Made by WORLDS BEST CABLES : Musical Instruments
Amazon.com: 3 Foot - RCA to XLR (Male) Cable Pair - Canare L-4E6S Star-Quad Audio Interconnect Cable & Neutrik-Rean NYS RCA & Neutrik Male XLR Gold Plugs - Custom Made by WORLDS BEST CABLES : Musical Instrumentswww.amazon.com
Monoprice 6ft Premier Series XLR Male to RCA Male Cable, 16AWG (Gold Plated) - Monoprice.com
An XLR to RCA cable converts a balanced audio signal into an unbalanced signal. This is good for sending audio signals from an XLR source to an RCA input, or vice versa. Regardless of direction, the rwww.monoprice.com
I'd rather have multiple gain options built right in then have to open it up and use jumpers. Especially since a lot of AVRs use ~1v outs. Also XLR -> RCA isn't always done in a standardized way, I'd rather have RCA in and keep things to a known simple standard. The Neurochrome board can take SE in and send balanced out safely.
Essentially, I'd like to see the Apollon general design without the extra overhead of Op-Amps by default (although a space add on them on afterwards would be prudent).
Vertical design is also nice, but it should be packed tighter together otherwise what's the point?
Also in the DIY thread they were discussing a new Hypex SMPS that will have all three channels the same instead of having to reverse one of the channels for 3 channel output and on the DIYAudio forums they were suggesting that the new powersupply would also have some other benefit with 'pumping' or something like that. So maybe wait for those.
