- Joined
- May 28, 2020
- Messages
- 1,658
- Likes
- 6,524
- Thread Starter
- #861
4-pole but 2-pole works with themAre you using 2-pole or 4-pole SpeakON connectors? Just asking because the link from geronimo1958 is for a 2-pole.
I understand and can only apologize. From what I've seen Nord is about to be in a similar boat (their current ETA is for the July Hypex restock which is now pushed back). If you need a 502 build sooner I think VTV still has stock but not sure how long that will last either.Bah, that was unfortunate. Was ready to pull the trigger on two nc502mp amps but September is a bit too long a wait.
Good news:
My case manufacturer has a new option I am working on right now that would help cut down on the height and move the screw locations from the front/back of the case to the sides for a better look. No timeline yet but working on the updates. No existing orders will be altered/changed.
Small cases are arriving today. The Medium and Large cases are in production.Is there an update on when these might be available? Thanks
Here it is, the new Small case (similar case coming for Medium and Large). Dimensions are still 12" deep x 7" wide but now shaved down to 3.5" with feet
I can only speak for my 4ch NC502MP: if I leave my AC Infinity Aircom off and watch temps, it never reports anything over around 95ish without any cooling/fans on.Any thought on how warm the NC502MP might get inside this case after a 90 minute movie? Thank you!
I have a 3 module 502 (6 channels). Use it pretty much all day long about 12 hrs a day 7 days a week. Temps rarely exceed 86 degree Fahrenheit. Have Aircom on top with constant temp sensor. After heavy Movie high volume of 2-3 hour length. However, this is all relative to the room ambient temperature. I maintain an ambient temp of between 76 and 78 degrees. So the unit will run about 10 degrees above room temperature.Any thought on how warm the NC502MP might get inside this case after a 90 minute movie? Thank you!
That's about how hot mine is with my Aircom running as well but my ambient temp is about 72ish. When it was located on a shelf above my Xbox One X it would hit 90 sometimes but that had everything to do with the heat of the Xbox.I have a 3 module 502 (6 channels). Use it pretty much all day long about 12 hrs a day 7 days a week. Temps rarely exceed 86 degree Fahrenheit. Have Aircom on top with constant temp sensor. After heavy Movie high volume of 2-3 hour length. However, this is all relative to the room ambient temperature. I maintain an ambient temp of between 76 and 78 degrees. So the unit will run about 10 degrees above room temperature.
Oh wow, yea I forgot how low impedance you were running. Glad to hear the amp is working great!Forgot to mention this unit is driving some very low impedance speakers. 2ohms loads. So it not cruising along driving easy speakers. I’m personally super impressed. I was somewhat skeptical about Buckeye’s claims these amps run so cool. But now I know matter of a factually they do. Class D amps are the real deal. Don’t know why I waited so long.
I thought the Buckeye amps come with trigger already installed.I am really happy with the trigger I built. Following up on a few posts here. I have been enjoying my recently received my Buckeye 2 channel amp and now have a working trigger solution to control the on/off. Long path but short answer... I bought a controller for an LED light strip. It is a compact unit that came with a 12v power supply and a remote control for $12.99 on Amazon. I connected a 3.5mm mono plug and trained my Harmony universal remote to control the device. It now works as hoped. I turn on the streamer with the remote and the Buckeye amps comes right on. The power off works just as well.
View attachment 136545View attachment 136546
Amazon Link for Controller
https://www.amazon.com/Lighten-Glimmer-Wireless-Control-Transformer/dp/B073VSF27Q/ref=sr_1_22_sspa?dchild=1&keywords=infrared+outlet&qid=1623875978&sr=8-22-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyMzA5SUNKTjlSQUlaJmVuY3J5cHRlZElkPUEwMTk4NzEwMUlKT1FRVUJLMVBZMCZlbmNyeXB0ZWRBZElkPUEwNDMwMTM1Mk84TVBINkdZMDBWVCZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
Amazon Ink for Plug
https://www.amazon.com/gp/product/B07Y8JBMY2/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Right, the Buckeye can be controlled with a trigger. But my streamer does not have the trigger output.I thought the Buckeye amps come with trigger already installed.
