- Joined
- Jan 1, 2020
- Messages
- 1,354
- Likes
- 2,034
Congrats
I will be receiving my 4 channel NC252MP soon. I will be powering my LCR which are Revel F36. They are 6ohm speakers. I'm trying to calculate estimated peak SPL at my listening distance. 8ohm spec for this amp is 150wpc and 4ohm is 250wpc. What should I expect for 6ohm? 200wpc? Thanks.
200 W is probably close enough. Peaks will actually probably be a bit higher, 225 W+, but you're likely already pushing what your ears can (or should) take.I will be receiving my 4 channel NC252MP soon. I will be powering my LCR which are Revel F36. They are 6ohm speakers. I'm trying to calculate estimated peak SPL at my listening distance. 8ohm spec for this amp is 150wpc and 4ohm is 250wpc. What should I expect for 6ohm? 200wpc? Thanks.
P = V * I = V^2 / R = I^2 * R so linear with respect to R meaning you can just linearly interpolate as you did to get 200 W. Ideally you'd get 300 W into 4 ohms, doubling as resistance is halved, to yield 225 W into 6 ohms and that's probably what it will do on short peaks.
HTH - Don
The NCx500 modules will be "readily available" towards end of Spring for OEM purchase.Are OEM NcoreX amp boards available for you yet? Do you plan to make your amplifiers with them?
read 4 posts upJust because I am too lazy to dig for it: @Buckeye Amps what is your current backlog, how long to ship an amp I order today?
Tnx - Don
Duh, four weeks, missed that. Long day... I'd delete my post but then yours would be hanging, so just leaving my inability to read or spend 10 extra seconds looking posted for all to see.read 4 posts up
I get why someone might want wall plates for certain loudspeakers in the room (box speakers like towers and bookshelves) to keep things tidy while also offering some flexibility for loudspeaker changes, as not every loudspeaker has the same inputs. But why have a wall plate at all on the AV rack side of things? Why not just have a pass through (rubber grommet or wall brush or simple hole) for all the speaker cables to connect directly to the amplifier? This would alleviate the need for another set of speaker umbilical cords between the wall plate and the amplifier(s).Off thread, but if I were wiring a huge home theater, I’d have a wall panel with SpeakOn connections for all speakers running to the AV room (instead of banana plugs).
Any estimate of how the new "x" offerings will be priced compared to current Hypex lineup, Dylan? I was planning on waiting until later this year anyway to get a new/more powerful 2-channel amp...The NCx500 modules will be "readily available" towards end of Spring for OEM purchase.
I do plan to make amp models with them, however working on shoring up the Purifi offering first.
My prelim estimate is around $649 for a mono and $949 for a 2ch.Any estimate of how the new "x" offerings will be priced compared to current Hypex lineup, Dylan? I was planning on waiting until later this year anyway to get a new/more powerful 2-channel amp...
Will add to first post:
EAT for new builds are as follows:
2ch and 4ch builds are 1-2wks
6ch and 8ch builds are 3-4wks
Still working on it...having an issue with the measurement rig that needs resolved first. May end up renting an AP if it comes to it.Is distortion issue fixed with Buckeye Purifi builds? Is it possible to fix?
