- Joined
- May 28, 2020
- Messages
- 1,671
- Likes
- 6,572
Hypex NCx500 specs:
- 700w @ 2ohm (per channel, peak)
- 700w @ 4ohm (per channel, peak)
- 380w @ 8ohm (per channel, peak)
You have a choice of two configurations (both at the same price):
- The default configuration uses the onboard stock Hypex buffer stage, which renders our Low/Med/High toggle switch inactive (gain cannot be changed). This configuration is best for use with an AV Receiver and/or when using other Hypex amplifiers in your setup.
- The optional configuration uses our Buckeye buffer stage (OPA1612 OP Amp), allowing for Low/Med/High gain settings via toggle switch on the rear. This configuration is best for use in setups with a source/DAC capable of higher pre-out voltages.
- Choice is not permanent and can be changed by the customer via internal jumpers at anytime.
Custom Input Buffer Board w/:
- Neutrik XLR connectors
- Low, Med, High Gain settings (if using our Buckeye buffer stage w/OPA1612 OP Amp)*
- Error Indication (via Front Power LED)
- Muted Soft-start/shutdown (minimizes speaker “pop” when turning on and off)
- Auto On/Off (along with Always On and 12v options)
*Gain settings, if using the Buckeye buffer stage:
4ohm - 24.2dB/3.3Vrms (High), 19.2dB/5.8Vrms (Medium), 14.2dB/10.3Vrms (Low)
8ohm - 24.2dB/3.4Vrms (High), 19.2dB/6.0Vrms (Medium), 14.2dB/10.8Vrms (Low)
*Gain setting, if using the Hypex onboard buffer stage:
4ohm - 26.8dB/2.4Vrms
8ohm - 26.8dB/2.5Vrms
NCx500 Mono Amplifier:
(1) Hypex NCx500 module
(1) Hypex SMPS1200A700
Neutrik XLR input
Standard 5-way Binding Post outputs
10"x13"x3.5" Aluminum case
NCx500 2ch Amplifier:
(2) Hypex NCx500 modules
Neutrik XLR inputs
10"x12"x3.5" Aluminum case
NCx500 3ch Amplifier:
(3) Hypex NCx500 modules
(1) Micro Audio 2kW SMPS (exclusive to Buckeye Amps only)
Neutrik XLR inputs
14"x14"x3.5" Aluminum case
*Rackmount case upgrade available for $150
*Free US Shipping
*International shipping available
Email directly ([email protected]) for buying or if you have any questions at all
Visit our website for up to date specs, pricing, and pictures:
Buckeye Amps Official Site
Neutrik XLR input
Neutrik XLR inputs
Neutrik XLR inputs
*Free US Shipping
