Buckeye Amps: Hypex NCx500 Official Thread
I live in Thailand and want to order Buckeye products. How do I order? And the module has a new NCx500. I don't see Multichannel
11ch including shipping costs.
For international ordering you would just email us and we can get the process started.
We don't offer more than 3ch using the NCx500 module...there is zero audible benefit using the NCx500 for surround and atmos speakers vs. the the NC252/NC502 models.
Dylan, your website still does not say that the watts are peak watts.
That will not fix Dylan's site, like Dylan said he would try to do.
you wrote this:
Troll Alert
I on the other hand, tire of members endlessly badgering another member in search of a very specific answer that the badgered member is not only unlikely to provide, but may not be in agreement with.
This isn't a court of law, its an internet forum; a place where ideas and views on a particular subject can be exchanged.
An exchange of views, not a cross examination.
More politeness, less contention.
IMHO
Still over the moon with the performance of my Buckeye NCx500 3-Channel after a year and a half. Thanks Dylan!
Have the same and have to agree with you. Would be nice to see testing of this unit in BTL configuration.
As @MicroAudio posted, even if you left the 3ch NCx500 in idle indefinitely, it does not get that hot. In fact when I tested one of the rack builds in my own setup, the AC Infinity Aircom would never come on while sitting idle, even though the thermal probe was placed right next to the SMPS and the temp for triggering on was set to 84F.
Couple of questions as I integrate AC Infiniti T5 cooling into my Buckeye rack mount amps. Would like to do it right first time as I have t remove the amps.
If beside the SMPS the optimal location for the AC Infiniti temp probe, where would the optimal location be in a 8 channel NC252MP amp?
Whats the best way to enable the probe to be placed inside the amp? Is there a suitable hole already in the case, or do I need to drill one? If so, any value in adding a 3.5mm jack or just feed it through?
When I used a probe with my AC Infinity, I placed it almost dead center between the (4) modules, slightly closer to one of the modules (doesn't matter which one).
You'd have to drill your own hole if you want to feed it through the back
Have a quick question, is there a idle power consumption difference between the 2 channel and 3 channel ncx500?
Planning on running 2 philharmonic HT towers and 1 HT center channel for LCR.
