Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Not with 8-ohm loads. As with all bridged amplifiers, the effective impedance of the load for each amp of the pair is cut in half. Hypex recommends avoiding 2-ohm loads, and frankly I would also avoid 4-ohm loads depending on how low and how widely the impedance curve dips. The driver you showed doesn't get below about 6 ohms and it is nominally 8 ohms and even then not at the frequencies you intend to use--no problem at all. 4-ohm speakers will work but will not deliver quite double the power of each separate channel. 8-ohm loads actually deliver more than double the power of the separate channels, probably because it's a better balance between the voltage and current requirements relative to what the amp can deliver.
My Revel F12's are nominally 6 ohms, with a couple of frequency bands that drop lower. They would be okay for the bridged amp, but I didn't bridge mine. The amp can already deliver just about everything those speakers can accept without damage.
Back in 2016, I documented the rise of class-D amps using the early TriPath technology. Used in the Bel Canto eVo 200.2, TriPath cracked open the door to the High End but was never admitted due to a dim and opaque treble. The second wave was based on B&O's ICEpower technology, again via a Bel...
This is a review and detailed measurements of the Buckeye Purifi 1ET9040BA (second generation?) monoblock amplifier. It was kindly drop shipped by a company and costs US $1,295. A single LED adorns the front indicating power on, protection or fault condition. Back panel has all that one would...
