- Joined
- May 28, 2020
- Messages
- 2,633
- Likes
- 10,960
- Thread Starter
- #21
While the name of the Micro Audio suggests 1300w max, it is actually capable of higher peak wattage.Rated power unreachable with those PSUs
We've been measuring them but I may be switching to the SMPS1200A180. I just want to do some more testing before making final decision since the A180 can theoretically exceed the max voltage of the 9040. Which wouldn't be destructive but if it happens would cause shutdown and obviously don't want that to be a scenario that occurs even if rare.Dylan,
What would the expected measurable power limits be for the Buckeye 9040BA build with the Hypex SMPS1200A100
at 8 ohms, 4 ohms and 2 ohms? Thank you.
Yea. This has been discussed elsewhere by others (not saying that in a dismissive tone).Looking at the 2 datasheets the OPA1612 (1.1 nV/√Hz) has a far better noise floor than the OPA1656 (4.3 nV/√Hz).
May be it is not something that we can hear but the difference is significant.
555?Also, we will be acquiring an Audio Precision for our business so rest assured there will never be any doubt in measurements again.
AP555X555?
Will follow up soon. Have to get the A180 stock in hand firstDylan,
How many watts are used with the Buckeye 9040BA and SMPS1299A180 config. while idle? Thank you.
Is there merit in slightly increased gain relative to a 1ET400 Amplifier so that the new amplifier can be driven to its full power direct from a 4V XLR DAC output?Very closely yes
4V will drive the 9040 to full power in High gain mode, yes.Is there merit in slightly increased gain relative to a 1ET400 Amplifier so that the new amplifier can be driven to its full power direct from a 4V XLR DAC output?
I actually would look for some lower gain values as I'd like some more volume granularity from my pre-amp (it currently has a choice of volume 6 a little too quiet or 7 a little too loud). So with a lower gain I could have more options between those two. May I ask what the gain options will be? (and you have the wonderful option to choose externally by some selector right?)4V will drive the 9040 to full power in High gain mode, yes.
High gain for the 9040 at 4ohm requires 2.9V
And the input impedance is now?OPA1656 Input Stage
The 1ET7040 offers marginally more power than the 1ET400 and then only when powered with a */-70V SMPS. It can however drive into low impedance speaker loads whereas the 1ET400 is best suited to speaker loads from 3 Ohms upwards if you want voltage clip to be the limit rather than current limit.Any future plans after the mono blocks to offer 1ET9040BA or 1ET7040SA in a 2 channel amp? Thinking of bi-amping Arendal 1723 Towers in my home theater. I considered the PURIFI 1ET400A 2 channel amp but was thinking they would benefit from the more power head room of the 1ET9040BA or 1ET7040SA. I also think the the extra capacitor board offered on these amps my benefit the amp powering the low end on the speakers as have my preamp to send the low end frequencies to both my front and subwoofers.
if you look through the ASR website you will see several contributors saying that bi-amping confers no benefit. But look at what @Buckeye Amps says on the subjectSo you don't think I would benefit from bi-amping vs a single mono-block amp per speaker? I currently have them to 2 Emotiva mono block amps rated 600rms 4ohms, i though i though about moving the mono blocks to another system and using the 1ET9040BA to power them. I currently using bluejeans cable 10AWG as the run is 26ft to the speakers.
www.audiosciencereview.com
Optimizing the 1ET9040BA means keeping the impedance to the speakers as low as possible to maintain its very low output impedance, which means very short speaker cables. My best-use case of a monoblock is one behind each speaker with a (potentially long) line-level interconnect (preferably balanced XLR) to each amp, and very short cable from amp to speaker. A long XLR cable, say <50~100m, will have insignificant effect on the sound (unlike a speaker cable of similar length).So you don't think I would benefit from bi-amping vs a single mono-block amp per speaker? I currently have them to 2 Emotiva mono block amps rated 600rms 4ohms, i though i though about moving the mono blocks to another system and using the 1ET9040BA to power them. I currently using bluejeans cable 10AWG as the run is 26ft to the speakers.
Close to it based on testing of one of the prototypes. Sure Dylan will publish exact voltage specs once testing completes.Does any know if they are any issues with using the Purifi amps in conjunction with a Marantz preamp. I have read some people have had issues with gain with marantz and certain amplifiers and not being able to get the full range of power out of the amp using the volume control on their reciever/preamp. I am currently using a Marantz 8805a and the other amps on the system have 29db Gain. Do you think i would run into any issues with the pre-amp using the Purifi amps or in conjunction with my other amps? I believe quoting marantz " When using the Pre-Out section from your AV model, the RCA pre-outs can output up to 1.2V and the XLRs can output up to 2.4V" I am using XLR wich would be 2.4v would i be able to get max or close to it with it in high gain mode? Marantz pre-out voltage
