Sorry to ask but any reason to buy this over the NCX500 (3 channels)? These are $55 cheaper for the 3 channel versionMainly things like power (do you need or want more power that the 9040 offers in monoblock form), timeline (sometimes one vs. the other is on back order or limited stock), state of the art...some people just want THE BEST there is even if it isn't an appreciable audible upgrade.
This is again why I have yet to offer more than 3ch for either the Purifi or Hypex NCx500....because when pricing amplification for surround speakers, the original NCORE MP series is still the best price vs. performance range.
o yes sorry i jus realised this thread is about 1ET9040BA and not 1ET6525SAI believe you mean the Purifi 1ET6525SA (which is not the same as the 1ET9040BA)?
With both the 3ch Purifi and 3ch Hypex NCx500, you would unlikely hear any audible difference. The choice mainly comes down to cost, availability, the better SMPS in the Hypex (for power/wattage), or just brand name preference.o yes sorry i jus realised this thread is about 1ET9040BA and not 1ET6525SA. Yes i am asking abt the 1ET6525SA
YES,and intelDid you say "Microsoft"?![]()
but later I accidentally touched the output line to the outer casing, and as a result, the power amplifier burned out, and there was no subsequent testing.
What the f... their short circuit protection, overload protection did not protect this condition?Actually, I have also done a simple test on 1ET9040BA, using the instruments DCA+E1DA APU+E1DA ADC. The THD+N is 0.000066% at 1K, but when the load is connected, the THD+N rises to 0.00030%. Of course, it has something to do with the ground of my power supply. Maybe my power supply is not well installed and not fully installed in the chassis, but later I accidentally touched the output line to the outer casing, and as a result, the power amplifier burned out, and there was no subsequent testing.
For clarity, this is not one of our customers as far as I am awareWhat the f... their short circuit protection, overload protection did not protect this condition?
That's surprising...
Thanks, but isn't the protection provided by the module itself?For clarity, this is not one of our customers as far as I am aware
The module has protection, yes.Thanks, but isn't the protection provided by the module itself?
Is there difference in protection between yours 1ET9040BA module amps vs other amps?
Or is it that your amp won't have such problem as he mentioned?
Thanks!
Short-circuit and overload is one thing,grounding the (balanced) output of a bridged amp is another.What the f... their short circuit protection, overload protection did not protect this condition?
There has to be a specific protection about it and also stated specifically (and a bold warning also) .
Yes,that's the proper way.View attachment 397047
1ET9040BA - Data Sheet (1.10)
It should be protected, but my actual situation did happen, and it happened twice. Both times, the MOSFET burned out. Of course, it happened when I tested with a sine wave. Maybe the music was not a problem. My 9040 module was purchased from the official store of purifi. Due to poor insulation between my terminal post and the chassis shell, when the signal was increased, the terminal post and the chassis leaked and arced, and the cause was found only after the second damage. It has now been repaired and sold.What the f... their short circuit protection, overload protection did not protect this condition?
Conditions matter and matter a lot.It should be protected, but my actual situation did happen, and it happened twice. Both times, the MOSFET burned out. Of course, it happened when I tested with a sine wave. Maybe the music was not a problem. My 9040 module was purchased from the official store of purifi. Due to poor insulation between my terminal post and the chassis shell, when the signal was increased, the terminal post and the chassis leaked and arced, and the cause was found only after the second damage. It has now been repaired and sold.
If I'm not mistaken, the protection threshold of the bridge amplifier is to monitor the sum of the two output currents. When only one side is connected to GND, the current on one side needs to be doubled to activate protection, which should exceed the current that MOSFET can withstand. There should be no problem with a short circuit between OUT+ and OUT-.
Those who have samples can try this operation, maybe it's just this one that has a problem. I dare not do 2OHM sine wave full power test, but those who are brave can try it.
www.audiosciencereview.com
