Buckeye Amps: 2nd Generation Purifi EIGENTAKT 1ET9040BA Amplifier
The Micro Audio SMPS1k-SN power supply upgrade is now available to be added during checkout on the website. ETA for the Micro Audio SMPS is 4-6wka but you can preorder now.
Who would benefit most from that kind of upgrade Dylan? Thanks!
Those wanting as much power as possible for under 4ohm loads.
The Micro Audio SMPS is also going to be better for continued power output (Sami stresses his designs thoroughly)
I think to take advantage of it you’d have to be running high gain likely and then you’d get the 200 watts extra into two ohms…. You can work out how much louder that would be on 89db speakers…. I’m not sure if it’s be audible?
Of course. It is mainly, like the 9040 itself, a good option for those who want the best regardless.
Hi Dylan, you posted measurements a ways back with the MA PSU, and mentioned you were going to also post hypex measurements. Is that still the case?
Yes. Want to get the AP situation sorted first. And then do a proper side by side measurement of the Hypex and Micro Audio (again)
Dylan, congrats on your business model and the way you conduct yourself here.
I see they are both "2nd generation":
What is the difference between the 9040 and the 6525 in terms of overall mechanism of amplification and secondly in terms of measurements?
The 6525 seems hard to track down
thanks a lot!
Hello All from Canada,
new here, and newer to audio....signed up as a result of this thread while researching the offerings on the Buckeye website
I have a question for Dylan at Buckeye that I thought might be better posted here instead of direct email so others in my shoes may benefit somewhat
Dylan I'm seeking a fast and energetic sounding amp.
I was looking at a pair of your Hypex NCX500 monos until I discovered your 1ET9040BA mono option
Can I expect the Purifi to be better for speed and liveliness? Am I even on the right path considering either option in my search for a fast sounding amplifier?
Please forgive my lack of technical knowledge and descriptions and thanks in advance
You will find these amps to be audibly transparent, thus sound the same as other amps with low output impedance, linear frequency response through the audible range, low noise, and ample power reserves. You will be delighted with the size, low energy use, and lack of heat of the design. You may also enjoy working with a company like Buckeye and a responsive entrepreneur like Dylan.
Unfortunately, any “fast” qualities, relative to other well-designed and adequately powered amps (and between these fine amplification modules), would come from somewhere downstream of your electronics and possibly even your speakers. Once you have a decent amp, searching for sound improvements with amplifiers is a waste of time.
Some here assert that the Hypex modules may not be as reliable over time. We haven’t seen adequate evidence for or against that. I have both and they are both going strong (Hypex>5 yrs), but that’s just my anecdote.
Are you in the Toronto area?
Alright I broke down and used audiophile terms, feel free to have at me all ;)
It’s the comfy chair for you.
"Speed" and "liveliness" are nonsense words cultivated by the audiophile press. What they tend to mean is actually a certain amount of coloration and distortion, and if that is what you like, the Purifi will probably be a disappointment for you, as it is simply neutral and transparent.
To simplify things as it pertains to this thread/amplifier:
The Purifi (and Hypex, as well) amps, including the 1ET9040BA, will not add to, subtract from, or in any other audible way alter the source sound.
Presumably other than voltage gain! :p
Reactions: JRT
Dylan, if neither alters the sound, what would be the main reason for me to choose Purifi over Hypex....if any?
Mainly things like power (do you need or want more power that the 9040 offers in monoblock form), timeline (sometimes one vs. the other is on back order or limited stock), state of the art...some people just want THE BEST there is even if it isn't an appreciable audible upgrade.
This is again why I have yet to offer more than 3ch for either the Purifi or Hypex NCx500....because when pricing amplification for surround speakers, the original NCORE MP series is still the best price vs. performance range.
If I may interject but don't take what I think as written in stone etc. I've been wrong before. The reason I would go for a more linear power output from a high power amp is for improved imaging due to much better flatter frequency response.
Yes, there is science in understanding how the mind perceives the measured sound. That doesn't mean the perception itself is science.
Pithy and accurate.
