The harmonics are lower, but I wouldn't say yours has an H2 problem. There is little difference in SINAD. Yours still looks in spec.
The SINAD (THD+N) in both those AP plots is set by the noise component.
Plots of the THD alone (no noise) will show the large difference between the analyzers.
I would expect Dylan (@Buckeye Amps) will be following AP's guidance on locating the source of the issue. If it is indeed the "high performance" analogue sine generator at fault, I would expect AP to look into it and rectify as that is arguably the jewel in the APX555B's crown and something AP is proud to tell the world how good it is.
H2 issues can also come from balanced outputs and inputs- simply changing to SE on my QA403 analyzer can make and H2 spur disappear completely.
Balanced inputs/outputs:
Single ended inputs/outputs:
I would have expected balanced to suppress even harmonics and single-ended to exhibit them worse. Weird. Probably because you're upside down in Australia.The SINAD (THD+N) in both those AP plots is set by the noise component.
H2 issues can also come from balanced outputs and inputs- simply changing to SE on my QA403 analyzer can make the H2 spur disappear completely.
No@Buckeye Amps are you going to increase the gain so a normal 2 volt rca source can drive the amp to full power?
I suppose you will need to wait for an Amir review to get the answer you need.Just trying to establish what's due to the analyser and what's due to your buffer.
Nice! That's what Bruno wants to achieve.I have the answers I need. My Buckeye 9040's sound.... like nothing. In a good way![]()
Perhaps you can share on diyaudio?I actually debate describing the sound differences in my system vs. my Manley Neo Classics (tube amps) and my long term loan S300 bel canto... but I'd just get yelled at for doing it![]()
Unless you are a bat or a dog!And you will never be able to hear the difference between 104 and 114dB SINAD.
If it helps at all, I have found my amps seem to sound best on low gain (the option to have this externally selectable being one of the reasons I picked a buckeye amp) and in playing my preamp at low gain I can't go above half its volume without the sound being stupidly loud on my 89 sensitivity speakers. I would probably get to volume 6 out of 30 in low gin preamp mode if I select high gain. Note, this is for the 9040 monoblocksNo
What does this mean to me if I want to use a WiiM Pro Ultra RCA out (rated max 2.1V RMS) as a preamp to a Buckeye Hypex NCx500 2-Channel? Will I have trouble reaching sufficient SPL? Will it still have transparent SNR?
Just a reminder that doubling the amplitude (voltage) is only 6 dB in volume.No
You would still have the low SNR/distortion. You just wouldn't get full power output. Quick math would say about 500w or so into 4ohm.No
And another reminder - 500 W to 1000 W is only 3 dB.You would still have the low SNR/distortion. You just wouldn't get full power output. Quick math would say about 500w or so into 4ohm.
No
No
Their FR measurement is without a filter (as noted in the datasheet). We did/do our measurements with a filter (AES 17 standard).@Buckeye Amps ... your 9040 based amp has a frequency response of 50kHz, yet one of the things Bruno said about what's new is the improved response up to 80kHz, per the datasheet. Does your buffer board have a role in this overall reduction? What is the FR of the standalone buffer board?
Secondly, have you submitted the 9040 to Amir for review? Sorry if I missed it.
Well, hurry up, my bats are really wanting to hear this amp!Their FR measurement is without a filter (as noted in the datasheet). We did/do our measurements with a filter (AES 17 standard).
At some point we will send one to Amir, yes. But likely not until we get more Micro Audio SMPS' back in stock.
