Buckeye Amps: 2nd Generation Purifi EIGANTAKT 1ET9040BA Amplifier
So you don't think I would benefit from bi-amping vs a single mono-block amp per speaker? I currently have them to 2 Emotiva mono block amps rated 600rms 4ohms, i though i though about moving the mono blocks to another system and using the 1ET9040BA to power them. I currently using bluejeans cable 10AWG as the run is 26ft to the speakers.
Optimizing the 1ET9040BA means keeping the impedance to the speakers as low as possible to maintain its very low output impedance, which means very short speaker cables. My best-use case of a monoblock is one behind each speaker with a (potentially long) line-level interconnect (preferably balanced XLR) to each amp, and very short cable from amp to speaker. A long XLR cable, say <50~100m, will have insignificant effect on the sound (unlike a speaker cable of similar length).
Bi-amping is of benefit when you use an active crossover and the amps feed the drivers directly. Otherwise it is a waste of effort and money for the vast majority of consumers IME/IMO. With very few exceptions, all my best experiences with bi-amping have been in a professional sound reinforcement application. Overview:
The price of the speakers is indirectly related to their power needs at best. What matters is their sensitivity, placement, and distance to the listener. You can use an online calculator as a rough guide (note 80 dB is very loud to me, so 100 dB peaks would be my goal): http://www.hometheaterengineering.com/splcalculator.html
Dylan @Buckeye Amps is one of the few dealers willing to assess what you need vs. what you want (and vs. what other marketing will tell you).
HTH - Don
Does any know if they are any issues with using the Purifi amps in conjunction with a Marantz preamp. I have read some people have had issues with gain with marantz and certain amplifiers and not being able to get the full range of power out of the amp using the volume control on their reciever/preamp. I am currently using a Marantz 8805a and the other amps on the system have 29db Gain. Do you think i would run into any issues with the pre-amp using the Purifi amps or in conjunction with my other amps? I believe quoting marantz " When using the Pre-Out section from your AV model, the RCA pre-outs can output up to 1.2V and the XLRs can output up to 2.4V" I am using XLR wich would be 2.4v would i be able to get max or close to it with it in high gain mode? Marantz pre-out voltage
Close to it based on testing of one of the prototypes. Sure Dylan will publish exact voltage specs once testing completes.:)
Any updates on 9040 monoblock release date?
Following with interest :)
More the point, has anyone used one yet ? I'm sure it sounds very good, given he previous generations did. But how about all that power ? Is this driving with ease with reserve ? An over kill ? Or yes, it really makes a difference to have that much in reserve to access in an instance ?
Enquiring minds need to know :)
HTH - Don
Hello.
Can you explain this a little more as to why you say this " best experience bi-amping have been in a professional sound reinforcement application"
Is it because you are using a speaker processor in the signal chain or something similar?
Thanks
Hello.
Thanks
Because many pro speaker systems are designed to be bi-amped using active crossovers and an appropriate set of amplifiers; they have no internal passive crossover (or minimal, e.g. just a blocking capacitor). Most consumer speakers with "bi-amp" terminals retain the internal passive crossovers, obviating a big advantage of going active, and AVRs send a full-range signal through both channels so do not include a proper crossover before the amplifier channels.
HTH - Don
I could put my front channel amp on a amp stand under my screen an use long xlr interconnects to them and do 5-7ft speaker cables or put them next to the speakers and do 3ft speakers but, i would not be able to put my aricom cooler above the amps if they were next to the speakers. Either way I am skeptical i would see an audible improvement over 26ft 10 gauge speaker wire. There shouldn't really be any high frequency roll off at that distance of 10 gauge wire.
Nothing to do with bandwidth, just maintaining very low driving-point impedance (damping factor) to the speakers, to keep the crossover (input) termination as low as possible. I wouldn't think thermal coolers would be needed but do not own those amps. My old class AB amps (also Emotiva but lower-power), in a console with some space above but no fans, are doing OK and have been for about 10 years or so.
I suspect in a blind test you would find swapping amps to be inaudible, let alone changing cables, just telling you what I would do to optimize connections to high-power amplifiers.
No what I do have does not run hot, it barely get warm after a movie or two, my monolith 7x gets warmer running my surround heights, not that it gets too warm either. I am not sure how warm a purify amp would get in comparison. As a computer guy that knows that what makes circuit boards susceptible to failure over time is the repeated heating and cooling of the circuits. A pc left running rather than being shut down every time its is not being used should last longer, excluding the cost of running it of course. I always aired(no pun intened) on the side of caution that cooling the amp even though it may not be nessicary might additionally help pronlg its life. Do you think it would make much difference between 3ft and 6ft that I should abandon having on an amp stand with a power conditioner and the aircom cooler?
I think it doesn't matter what I think. ;) But 3' vs. 6' of speaker cable I would expect to be inaudible.
For the record, you can check various sites for MTBF/MTTF that indicate it is better to turn the PC off when not in use, but it depends upon what failure mechanism is involved. Thermal cycling tends to expose poor solder joints and other connections; continuous operation reduces semiconductor, capacitor, and other component operating lifetime. That said my career was more high-rel industry and mil-type stuff not commercial PCs.
When driving high-sensitivity, easy-to-drive speakers, will EIGENTAKT 1ET9040BA amps sound any better than 1ET400A amps?
I am pretty sure no-one could hear a difference in a proper controlled test.
At 100+dB/2.83V/1m Blumenhofers we couldn't tell 1ET400A from AR 160M monos.
So...
Maybe with low sens speakers at far-ish listening distance and a big room 1ET9040A would make a difference.Otherwise,no.
When upgrading your amp from 1ET400A to the 1ET9040BA the only difference in sound will be the ATM running twice as hard and your wife wondering out loud if these new amps were really needed. :D
Will we see measurements posted before preorders open up? I'm expecting to put in an order.
ETA for taking orders will likely be beginning of July.
I have plenty of the 9040BA modules heading to me soon (ordered and in stock from Purifi).
The Hypex SMPS1200A180 is on back order until July.
And the Micro Audio SMPS1300w SMPS optional upgrade is currently in manufacturing, similar ETA of July as Hypex.
Everything else is ready to go (input board is measuring as expected, which is to say it is not imparting a negative effect on the performance expected).
