- Joined
- Jul 12, 2024
- Messages
- 2,751
- Likes
- 4,203
Does it matter if it matters? What kind of question is that?Does it matter?
Just that there is a lot of audiophile old wives tales about analog attenuation supposedly being better than digital.Does it matter if it matters? What kind of question is that?
Not better, safer.Just that there is a lot of audiophile old wives tales about analog attenuation supposedly being better than digital.
In what way?Not better, safer.
Nicely made they are immune to glitches, unlike digital ones.In what way?
If the criteria is "nicely made", then digital ones ate immune to glitches too.Nicely made they are immune to glitches, unlike digital ones.
The horror stories we read are just the tip as only a few brave ones report them.
It's a second point of failure, hence safer.If the criteria is "nicely made", then digital ones ate immune to glitches too.
I have lots of horror stories of gear damaged by analog volume controls too. Some because of teenagers, some because of contact issues.
We're not talking user errors here, these are common to both.If the criteria is "nicely made", then digital ones ate immune to glitches too.
Again, I also mentioned contact issues. They are not user errors. There are good and bad digital controls - just as there are good and bad analog controls. You can't specify "nicely made" for one category and then compare it to the worst examples of the other.We're not talking user errors here, these are common to both.
Have a look around at the DX5 II thread and the +20dB jump with their digital controls.
Or others who "forget" their settings after a power cycle, an update, etc.
Want to go bigger? Go to the Microsoft giant and to the famous "brrrrrrrr" at 0dB with just a BSOD.
No point to expand, these are very well known hence the sane advices about passive attenuators or physical hard-limiters at digital VC systems.
No, I'm talking about both nicely made. Analog nice ones last for decades with zero problems and very tight tolerances.Again, I also mentioned contact issues. They are not user errors. There are good and bad digital controls - just as there are good and bad analog controls. You can't specify "nicely made" for one category and then compare it to the worst examples of the other.
So do digital.No, I'm talking about both nicely made. Analog nice ones last for decades with zero problems and very tight tolerances.
Nope, I just gave you the best example around, which combines the best of both worlds.So do digital.
We are going around in circles here. Even the best analog controls can also fail.Nope, I just gave you the best example around, which combines the best of both worlds.
But even that can (admittedly very rarely) fail at its digital side.
If you say so.Buckeye's decision about analog one is wise, and stepped attenuators have zero difference between channels.
I'll try to have that in the next week or twoAhem, not to derail this learned volume control sub-thread, but @Buckeye Amps when will you have estimated pricing?
Didn't forget about this but a little hard to give pricing at the moment as final cost is still being tacked down now that we are close to quoting parts ordering, etc.Ahem, not to derail this learned volume control sub-thread, but @Buckeye Amps when will you have estimated pricing?
On the back, maybe call it OUTPUT instead of OUTPUTS as there's only one outputAs requested, some pics. The front panel LED lettering are actually white, not sure why they show up blue
