Buckeye Amps 2ch Integrated Amplifier
As requested, some pics. The front panel LED lettering are actually white, not sure why they show up blue
Very nice. Eagerly await testing.
Did you get a custom display made with individual LED segments?
Can they be dimmed or disabled? Disabled meaning they light up when I change something, then go out a few seconds later.
It is a custom LED segment display. And yes, you can dim the display with a button on the remote
Is this intended to be compatible with all the hypex and purifi lines?
Yes, any 2ch we offer now would be compatible
Will I be able to order it without an amp and power supply so that I can use the ones from a previously purchased Buckeye amp?
Dylan,
Are you still looking into offering the option of incorporating Dirac Live via an add-on card for this integrated amplifier ?
Dylan,
That feature is likely hanging on by a thread in terms of what we may offer as part of the upgrade path. Unfortunately learning to keep things a little more on the simple side.
Does the development of this integrated amplifier give a greater appreciation of the gestation period of a cow elephant ? :)
Along the same lines, wasn’t there discussion about perhaps adding some sort of digital input possibly through expansion? (Or am I misremembering that?)
That would still be the plan for the expansion card (to essentially expand the base model into a DAC/digital input capable)
Is the volume digital or analog? Sorry if this is answered already.
