That is the goal, yesWill it be truly balanced?
Oops... Marantz Stereo 70s seems to be 2.2 capable, it has two subwoofer outputs!The Cambridge audio amps like AXA/CXA have 2.1 implementations, I believe there are many more 2.1
The Buckeye integrated would be the first 2.2 amp !!! with L/R sub-outs, I hope it will support speaker configurations 2.0, 2.1, and 2.2 with a cross-over setting.
Yes for the 7040.Super stoked! So you’ll have the 7040 available at launch?
Also any updated pics?
Dunno…Yes for the 7040.
No new pics. Right now is the "non-sexy" work of firmware and PCB board finalizations.
RCA Outputs (x2)
- User specifies desired behavior at checkout
- EX: User could specify Mono Sub outputs w/Low Pass Filter (24dB Octave, Analog)
- EX: User could specify Stereo Sub outputs w/Low Pass Filter (24dB Octave, Analog)
Filters will be fixed. Values to be determinedIs the Low-pass filter fixed or variable/selectable? if fixed what is the freq or available freq to choose from?
Is there a High-pass filter available for the speaker outputs? if yes is it fixed or variable/selectable?, and will it be switchable(on/off)
Somewhere around $1700/$1750@Buckeye Amps, pricing on the 7040 integrated?
Will any of the add on feature cards allow for DSP based cross-over capabilities on the pre-outs? Also are you planning for two channel Dirac or four channels with Bass Control DIRAC that works with he subwoofer outputs?2ch Integrated Amplifier Specifications/Features List (w/o Add-on card):
XLR Inputs (x2)
RCA Inputs (x2)
RCA Outputs (x2)
- EX: User can opt for no Filter Card and use RCA Outputs as full range Pre-outs
- Filter Card is user changeable (can order multiple iterations for minimal cost)
- If Filter Card is installed, user can switch RCA Output behavior (Pre-out vs. Sub out) via Remote
5-way Binding Post Speaker Outputs
- If user has selected a Filter Card for their sub outs, then a High Pass Filter (24dB Octave, Analog) will also be applied to speaker outputs
Volume Control Knob
- Stepped Attenuator (0.5dB steps w/128dB range)
- Press knob to mute system
Front Power Button
- Single press turns unit on
- Press to cycle inputs (once on)
- Hold to turn off
Remote control (metal)
- Includes Dim button for Front LED Display
Supported 2ch Configurations:
- NC252MP
- NC502MP
- Purifi 1ET400A
- Purifi 1ET7040SA
- Hypex NCx500
Software Features:
- FW Updates (via Phone or WiFi)
Add-On Card Features being explored (for future release)
- DAC
- Dirac Live
- Parametric DSP Filters
- HDMI EARC
The Add-on card details are still a work in progress. So I cannot give even "possible" solutions. But final details will be hashed out and concrete before we sell the base model integrated.Will any of the add on feature cards allow for DSP based cross-over capabilities on the pre-outs? Also are you planning for two channel Dirac or four channels with Bass Control DIRAC that works with he subwoofer outputs?
Most likely not. Only so much we can accommodate.This is great. Looking forward to the final product! Any chance an A/B speaker output will be added so you can have two sets of speakers connected?
Will it have auto sensing?2ch Integrated Amplifier Specifications/Features List (w/o Add-on card):
XLR Inputs (x2)
RCA Inputs (x2)
RCA Outputs (x2)
Volume Control Knob
Front Power Button
- Hold to turn off
- NC252MP
- NC502MP
- Purifi 1ET400A
- Purifi 1ET7040SA
- Hypex NCx500
Software Features:
- DAC
- Dirac Live
- HDMI EARC
I will have to answer this when the PCB board design is finalized.Will it have auto sensing?
Awesome feature! I like the idea of fixed freq. via cards as opposed to a pot or DSP.If user has selected a Filter Card for their sub outs, then a High Pass Filter (24dB Octave, Analog) will also be applied to speaker outputs
