Buckeye 3 Channel Purifi Amp Review
Rate this amplifier:
    Votes: 19 6.9%
    Votes: 66 24.1%
    Votes: 151 55.1%
    Votes: 38 13.9%
JPA
Burque
Change of subject but related to review.
Question for those who know more than me. I have a Adcom rated at 200 watts (8 ohms) per channel RMS amp driving my old 4 ohm MK 100Bs.
The spec on the Buckeye amp states 225 watts per channel at 8 ohms, but the review states 156 watts at 8 ohms.
Would I be loosing power and/or dynamic range replacing my old Adcom 555II amp with the Buckeye Purifi 1ET400A 2 channel amp?
I don't understand the power rating compared to the review. Thank you in advance....
I don't wish to be rude, but if you're going to change the subject start a new thread.
OldFart
Salisbury, NC
Sorry, maybe I should have wrote new paragraph as my question was related to the Buckeye amp review and power ratings.
and yes it is not always easy to know when to start a new thread so as not to offend someone.
Descartes
This was not expected and was not an attempt to have a known/flawed product pushed through review.
While we did robust testing during development and prototyping, I cannot account for why this issue was not identified or observed early on. But I do take full responsibility.
As Amir briefly acknowledged, now that we are aware of and able to reproduce the issue on our end, we have been testing furiously to identify the exact cause so we can produce a fix.
Transparency and communication with the community has been one of the "pillars" I've tried to build my business upon. As soon as we identify the exact issue and the appropriate fix, it will be implemented ASAP, including for current customers as needed.
Looking forward to to the 2.0 version!
Too bad the boxes are not better. My amps sit in the open so esthetics are also important to us!
Buckeye Amps
musicforcities
The case doesn’t look very well manufactured. There’s large gaps all along where the top and bottom meet.
The gap is uneven (wider towards the center). However I think it is more likely a variation of material tolerances (corrected, not stamped) : schiit manages it only by having tiny boxes. it also might be an issue isolated to this unit.
And rather than try to bend it back as someone suggested here (hard to do actually and not cause other distortion), in such cases it usually better to epoxy an l or c channel or two to the inside, clamping it in place until dry. That will flatten the curve without risking deformation.
Or enjoy the wonders of industrial Velcro tape. Problem solved.
And can I just say, regardless, the manufacturer’s responses here indicate great service would be forthcoming. Amazing
Reactions: JRS
Buckeye Amps
And uneven (wider towards the center. However It is hard to get stamped sheet metal of that thickness so flat: schiit manages it only by having small boxes and using aluminum. a bolt in the middle would help
Just for clarity, not stamped sheet metal. The cases are aluminum
musicforcities
I stand corrected and edited my post accordingly. By stamped I meant bent by deformation (not cnc’d, etc).
And again kudos to you for your engagement here. I would have zero qualms about the case issue. I actually was trying to say that it’s not a case (sorry about the pun) of poor manufacturing but likely a fluke and an inherent limitation in tolerances of the metal and forming process itself. Which is even harder to manage at what I guess are small runs.
And using less material for lids is good: lighter unit, better heat transfer likely and better for the environment all around. Money spent where it counts. As is part reduction. So I applaud that.
Though I would pay a couple hundred more for nice giant VU meters like my old luxman m2000. I know pointless.
FYI: I inherited a ayre cd player that has machined aluminum 20mm sides, 15mm front and a top/bottom plates 3.5mm thick. weighs a ton. Looks amazing. And is most wasteful and stupid case design I ever encountered. I’m sure they would claim some bs about vibration. Or resonance or magic string theory. Whatever, it still measures worse than a $100 disc man from the same era. Better off streaming medium bit rate on Spotify. Or using it as the most obscenely absurd transport with the digital out to a cheap topping DAC. Even my cheap AVR DAC is better.
Chrispy
PNW
FYI: I inherited a ayre cd player that has machined aluminum 20mm sides, 15mm front and a top/bottom plates 3.5mm thick. weighs a ton. Looks amazing. And is most wasteful and stupid case design I ever encountered. I’m sure they would claim some bs about vibration. Or resonance or magic string theory. Whatever, it still measures worse than a $100 disc man from the same era. Better off streaming medium bit rate on Spotify. Or using it as the most obscenely absurd transport with the digital out to an AVR.
That one of the Ayres that simply had a fancier case around an Oppo player? :)
musicforcities
That one of the Ayres that simply had a fancier case around an Oppo player? :)It
Not to hijack thread:but no it was before that model. It’s well built inside at least with balanced outs. It plays sacd, dvd-a, anything really. which is why I keep it. You just have to use the digital out or at least keep a dip switch set to “measure” (a sharp filter I think)rather than “listen” which rolls off the highs like it’s a bad tube preamp and creates high order distortion I can’t hear.
Anyway…I’ve been perusing the shopping pages at Buckeye …
I think they should offer a version of the same models but housed in a solid block of aluminum and charge 15x -30x the price for only $200 extra material costs and put a dip switch on the back that allows you to “listen” to the special inaudible distortion artifacts discovered here, or “measure” with the fix. and big warm VU meters
musicforcities
There appears to be several or more peeps looking for a class D amp with big VU meters. A common request although finding suitable big VU meters is apparently not so easy. :D
It’s like piping motor sounds through the stereo of electric cards …comfort eye candy. But yeah, they need to be nice ones which are rare. The old luxman ones were gorgeous. No blue leds allowed either.
Buckeye Amps
Enough people have actually made this comment over the last year that they would be interested in VU meters that I feel I should give an official answer: I myself do not plan on offering them as an add on option.
However, I do work very closely with @Rick Sykora who does custom work/builds. If anyone was seriously considering one of my amps but is holding out for VU meter integration (or another such visual modification along those lines), there is no harm sending him a message to get his thoughts, etc.
Sokel
I have try HARD to find the source of the Audio Research meters but no success :(
(no more OT,I promise!)
Rick Sykora
Stow, Ohio USA
While somewhat OT, good VU analog meters are simply hard to find. The last ones I used were plastic and needed a custom glass bezel to protect them. I looked again today and no real change. With supply chain issues, they are seemingly not a priority. Many legacy products that have VU meters are often too expensive to consider retrofitting with new amplification.
As for more on topic news, as @Buckeye Amps reported, the distortion rise is reproducible by those closest to the situation. The challenge has been validating potential remediation as the designer has had test equipment issues. As many know, supply chain issues have hampered test equipment availability too. The designer has had to consider alternative test equipment and, along with personal priorities, progress has been slower than expected. He is pursuing multiple potential solutions and expects to have resolved very soon. Stay tuned and will update as soon as we can! :)
AdamG
Debunking the “Infomercial” hawkers & fabricators
Moderator
Reality
And with that, let’s get back on topic. This is an Official Review Thread and we try to keep the conversation on topic. Please start a new thread to further discuss VU meters. Please and thank you for your understanding and support. ;)
Fuzzy
United States
I bought the 2 channel version of this Purifi amp from Dylan at Buckeye last year and received it in September. So I have been following this thread with interest and doing my best to understand the issue. I am using the Buckeye amp with a direct XLR feed from a RME ADI-2 dac. The dac is connected by usb from a Intel NUC running JRiver. Speakers are Ohm Walsh 3 with replacement drivers. The Buckeye amp took the place of a venerable Adcom amp. I have been using the low gain setting on the Buckeye Purifi amp. With my old ears I am very pleased with the music I am hearing. I believe this amp is distinctly better than any amplifier I have ever had in this system. I use a Benchmark amp and pre-amp in my upstairs system. I haven't been able to hear anything that seems like it could be the distortion that was found in the testing. It is just clear and quick and the lower frequencies sound particularly good. I am pretty sure my ears are the weak link in the chain at this point. I really do appreciate the perspectives that everyone is bringing to this.
I found Dylan to be a great and responsive guy when I was ordering the amp and have been impressed with how he is handling this situation. I would buy his work again.
Thanks!
