a single amp will do if it has very low output impedance (reduce the common impedance). this is where damping factor actually matters (it does not matter as much for the bass as folks believe because the dominant resistance is the voice coil anyway)
That would be enough for me to cross the speaker off my list. I won't pay for snake-oil parts. I won't even pay for dual binding posts on speakers with passive crossovers and no active crossover option sold by the manufactruer (so goodbye Revel and KEF, among many others).
I'm fine either way. Often enough, features you don't want are what allow the product to be sold to a customer base that is large enough so that developing and manufacturing a product to make sense. And also a larger customer base means greater economies of scale, so the product might not even end up more expensive.That would be enough for me to cross the speaker off my list. I won't pay for snake-oil parts. I won't even pay for dual binding posts on speakers with passive crossovers and no active crossover option sold by the manufactruer (so goodbye Revel and KEF, among many others).
That's a big reason why I own a pairAnd Ascilab speakers are snake oil free!![]()
I never heard this claim before. It does not make any sense to me. Got a link to a technical explanation?dual binding posts makes some technical sense since it bi wiring reduces cross talk between the drivers. not saying it’s necessarily audible though
Isn't bi-wiring the same electrical circuit as single wiring? In both cases the tweeter and woofer including their accompanying HPF and LPF are in parallel, the only difference being the length of wire between the drivers and the point they are connected in parallel?it follows from Ohms law: when you drive two circuits via a common impedance then voltage arising in one circuit leaks to the other in proportion with the common impedance.
So the difference is the impedance of one run of speaker cable versus the combination of two runs of cable in parallel?its the cable impedance and amplifier output impedance that is common. Yes, in parallel but with a little bit of common impedance
Appreciate the clarification.no. in bi wiring the cables are not common anymore. then it’s only the amp output impedance.
Their main merit, as I see it, is to allow for active bi-amping without butchering the back panel: you can just set a clean by-pass of the passive Xover through reversible internal wiring mods, plug each driver direct to its amp channel and experiment to your heart's content.Yeah, the dual binding posts annoy me to.
From a technical point of view I agree, but that’s a very niche benefit use-case. The main reason for bi-wire terminals is to appease those that want it, thereby catering for more customers. I suspect many manufacturers don’t believe in there being any audible/technical benefit, but include it as a feature to attract as wide a range of customers as possible.Their main merit, as I see it, is to allow for active bi-amping without butchering the back panel: you can just set a clean by-pass of the passive Xover through reversible internal wiring mods, plug each driver direct to its amp channel and experiment to your heart's content.
This is not correct. The cable impedance still contributes.no. in bi wiring the cables are not common anymore. then it’s only the amp output impedance.
I think it'd be difficult to measure any difference acoustically (let alone hear a difference), but no, it is not electrically identical:Electrically, bi-wiring is exactly the same as single wiring using both sets of cables (to the single terminals).
Your 2nd diagram is bypassing the internal crossover. That is indeed different, but then you need an external crossover to send a different signal to each driver. That would be bi-amping, not bi-wiring. For bi-wiring, the internal crossover is not bypassed, and then the 1st diagram still applies (with additional crossover components not shown).I think it'd be difficult to measure any difference acoustically (let alone hear a difference), but no, it is not electrically identical:
Z1-Z4 represent the impedances of the individual conductors in the cable(s). Think about the current flow and you will see that the two cases are not the same.
Adding crossover components would make no difference; the two circuits would be still be independent from the binding posts to the drivers. There may be some speakers where the negative ("ground") terminals are tied together internally, but there's no reason to do this and it could cause major problems (e.g. if one were to try biamping).Your 2nd diagram is bypassing the internal crossover.
Audibly identical and electrically identical are not equivalent. I would roll my eyes if someone were to claim (without real evidence) that biwiring makes an audible difference, but the claim that the two configurations are electrically identical is false.Certainly looks different on paper but utterly meaningless when the actual results are identical. Surprised to see bi-wiring met with more than a eyeroll.
Audibly
