You are correct. Set speakers to small, select crossover frequency for both speakers and sub, set distances to speakers and sub, run roomEQ on platinum hub.I just picked up a Sub 10 to pair with my A10s and Platin hub. I'm a bit confused about the wireless setup, and am hoping someone here might be able to share their experiences.
Am I right in thinking I should:
1. WISA pair the Sub with the Platin Hub
2. Set *only* the sub distance in the app (no low pass, no room eq)
3. Room eq the Platin hub only
If that's correct, what about the back of the sub? I assume I won't need to then touch the phase control, as the app should take care of it? But what about the volume control? Seems like that still affects the sub, so I'm not sure where to set it...
Thanks both!
@Chromatischism as far as I can tell, the Buchardt software doesn't guide you on adjusting the sub's level, frustratingly. It could be user error, of course.
Unfortunately you can't adjust the volume through the app, you need to use the dial on the back of the sub.
You can't adjust the main level on the sub through the app. - just as with any other sub, it has to be adjusted with a dial on the back.You're kidding, right? That's crazy.
SVS subs let you adjust gain via the app...just as with any other sub, it has to be adjusted with a dial on the back.
Fletcher & Munson have entered the chatNot that you should ever need to after you set it up.
Loudness EQ should be done system-wide, not by turning the knob on the back of your sub / in your sub app.Fletcher & Munson have entered the chat
Thinking of adding a second sub in my HT setup (open space large volume room, high ceilings, soon to be full dirac). I already have a Kef KC92 and I am undecided whether to get another one or go for this SUB10. KC92 would be some300100 EUR more expensive. Any thoughts? Is there any benefit from going with a different characteristic for the second sub?
I agree with Ken, stick with the same sub. Introducing two different subs can cause more issues.Thinking of adding a second sub in my HT setup (open space large volume room, high ceilings, soon to be full dirac). I already have a Kef KC92 and I am undecided whether to get another one or go for this SUB10. KC92 would be some300100 EUR more expensive. Any thoughts? Is there any benefit from going with a different characteristic for the second sub?
