I just measured both. Keep in mind these are low res/in-room (1/12, on-axis and nearfield) measurements. As always, I averaged several (5) captures for each Tuning :
Massive difference below 30Hz and post-10Khz.
The drop in sub bass helped a lot (9db less distortion in that area). But the rest is overall worse all the way...
There's new trouble coming, tho... I now have a little popping noise almost each time speakers receive a signal... and a few seconds after the signal is gone. Like it would continuously wake up and go back to standby mode... (Note that I'm not using this completely fucked-up Hub anymore, so upgrade was not even a thing)
I also notice back LEDs (channel indicators) are way darker than before. Same for you?
Edit: There is
already a fix coming:
