There are many reviewed here. I just got my mom a WiiM amp with PEQ, it is great. I used the room correction to help her out in her apartment, she seems happy. I like the sound. I have PuriFi and Hypex, they are both great too but overkill for many, likely including myself. I did get them because the are used in a high efficiency system where the noise is audible. but barely to be honest. Otherwise the 3BST, assuming yours is performing like mine, is going to be so awesome that even a more awesome amp isn't going to make one iota of difference in the sound.
Mine do not, unless I hook them up to a really high efficiency speaker like a compression driver on a lens. Even then, I have to get my ear very close.
Are you sure it's the amp? Or is it something the amp is amplifying that the amp is hooked up to? Most likely, usually free to fix, is a ground loop.
If it is the amp, Bryston can likely fix it.
If I had a Bryston amp and didn't need another amp, I would buy a new pair of speakers.
Amps that are working properly just don't have any sound.
