Could perhaps also be due to the other power supply and less to the purify.
Have you peeked inside? I would be interested to know if the PSU is a customised Hypex or are they using another supplier.I agree with you on that. What caught my curiosity after seeing this thread, then visiting March Audio to see what they were doing in this front, was their description of their new switching power supply. In their words: output is not dependent on mains input voltage variation (so you always get the expected output from the amp) and larger output capacitence to lower 'buss pulsing' on transients.
Just listened to:
Deep Purple - Machine Head, especially Smoke on the Water, 2011 Japanese remaster in DSD64, and
INXS - The Swing, 2013 remaster in 192/24.
I play both a lot, and loud, and in both instances the bass track is more authorative and there is now no (or less) compression on crescendo everywhere, I didn't know I had compression until this change.
I do think the power supply is firmer, there may be some dynamic improvement in the 7040, can't tell from my seat where it's coming from, just know it's coming from somewhere other than my imagination!
Probably quite different than the Hypex SMPS1200A400 since the amplifier has a universal 100-240V rating without any switches or jumpers. Suggests that the power supply is stabilised against input voltage variation and therefore might also be stabilised against load variation. The Hypex SMPS are not perhaps built to the same standard as the Purifi modules so it would be interesting to see a teardown or even just some nice photos on the March Audio webpage. March audio quality appears to be very good and if they have beaten the competition here then that is a further reason to consider them for quality builds of Purifi amplifiers.Have you peeked inside? I would be interested to know if the PSU is a customised Hypex or are they using another supplier.
To keep inventory and manufacturing costs down I would not be surprised if March Audio is using the same PSU in the P421. The P421 is wider the the original P451; I think uses the same case as the P501. It would make sense to to use the same PSU.
According to their website: “The new main power supply is custom designed and a significant improvement over the Hypex unit previously used. It has very low noise with high current output and excellent voltage regulation. Efficiency is improved with power factor correction.”Have you peeked inside? I would be interested to know if the PSU is a customised Hypex or are they using another supplier.
Yes, I suspected that the PSU was the same. Well, at least in the P421 and P501.I haven't had a peek inside, thought I would leave it to a reviewer who doesn't have the worry about warranty or scratches.
I can confirm the new touch power switches work great. I was annoyed with the old P451 solution and resorted to using a simple trigger set up (9v battery in a plastic box with a switch) which worked fine.
Having played the system for three days I am sure the new power supply has a big input to the transient improvement I'm hearing. Hope my posts from day 1 weren't too over the top, I was excited with what I heard.
From what I understand the new power supply is now standard across the range.
Thanks, I really appreciate the type of posting you do, very informative, direct, and helpful! I read about the new 1ET7040SA but couldn't find any good info on real-world differences between it and the 1ET400A in stereo applications at 4 ohms and above (even today in May '22) and your post from Jan of this year makes it abundantly clear!! Thanks again, I wish you were a US supplier as I would have purchased from you.Since there seem to be some confusion around the power of these new modules, lets clarify a few things:
1. the 1ET400A power is limited by power supply rails voltage for loads above 3.3 Ohm.
2. the 1ET400A power is limited by its self-protection for loads below 3.3 Ohm.
3. the 1ET7040SA power is limited by power supply rails voltage for loads slightly above 2 Ohm.
4. the 1ET7040SApower is limited by its self-protection for loads below slightly above 2 Ohm.
This means that with an identical power supply, both 1ET400A and 1ET7040SA deliver the exact same power for loads above 3.3 Ohm
Any OEM using an Hypex power supply and selling more than 210W in 8 Ohm for either 1ET400A or 1ET7040SA is misleading at best.
Compared to the 1ET400A, the interest of these new modules is their ability to deliver huge amounts of current in very difficult loads. For more "normal" speakers, no notable difference.
Small typo from post #50 of this thread but I believe you are referring to it being the same above 3.3Ω (ohms vs volts) when using the same PSU.Anyhow that doesn't change anything to my initial statement: the 1ET7040SA will deliver the exact same power as the 1ET400A above 3.3V when powered by the same PSU.
It is the control board, modulator on one side, microcontroler on the other side.I've been wondering for ages, and never seen it mentioned, so I'm going to ask, despite it not being very important.
What's the riser board on the amp? Why separate stuff out? Just lack of physical space?
As I type this, it occurs to me that it might be a microcontroller. Is it?
Being in the US not familiar with the EU Low Voltage Directive, so gave it read over but wasn't obvious what "all the advantages associated with being excluded" were. If your supposition is correct, can you briefly outline what those advantages are?Having the supply rails specified with absolute max voltage +/- 75 V DC like the 1ET7040SA allows to be excluded from the EU Low Voltage Directive scope with all the advantages associated.
EU LVD is a set of safety regulations. If a product is concerned, it represents non negligible additional costs for demonstrating the compliance to these rules. This is a reason why most affordable products that need mains supply use an external generic power supply. The cost associated to LVD is shared between all the power supply users while the product itself is not concerned.Being in the US not familiar with the EU Low Voltage Directive, so gave it read over but wasn't obvious what "all the advantages associated with being excluded" were. If your supposition is correct, can you briefly outline what those advantages are?
