I found my "old" CD on the DR database...DR measures as good or better than the BR. No wonder it sounds so dynamic
As long as I'm good with only a stereo mix at 16/44.1
“As good or better” is not the right term when it comes to DR measurements. You should instead say “equal or higher”, as a higher DR is not always an indication of “better”.
The thing is that a less bassy version of a song usually end up with a higher DR number. So without making a listening comparison, its a chance that the version with a little lower DR numbers can as likely be the version that sounds better balanced of the two, or the other way around, you never know.
Just wanted to point that out, so that no one thinks that a higher DR number always means it's better.
