I have this nice IEM cable that had the plastic black separator ring break off and now it won't go into any 3.5 mm
socket. How hard would it be to replace this plug?
If it fails you try it again. There are all kinds of 3.5 mm plugs, see locally what you can find. You can even use one from other old/broken cord if you have such somewhere.thanks for the replies. At least it's possible. Can you guys give me a suggestion where to buy such a plug? I can solder but not sure if something this small is in my wheelhouse but I can try and if I fail-it wasn't working anyway, right?
The problem is there's a distortion in the distal part of the proximal piece where the metal has expanded so it's too large to go into a socket.It's a long shot, but maybe you can fill the gap? Maybe wrap some fine thread around until it is filled and then add epoxy to that?
Thanks. I'd like to have the type where there isn't splicing involved-that never lasts long. I'll check Amazon.If it fails you try it again. There are all kinds of 3.5 mm plugs, see locally what you can find. You can even use one from other old/broken cord if you have such somewhere.
https://www.ifixit.com/Guide/Headphone+Plug+Replacement/40154
Afterwards who knows me by you make your own costume cables.
You can't just fix that with a blade, or maybe a coring bit or something?The problem is there's a distortion in the distal part of the proximal piece where the metal has expanded so it's too large to go into a socket.
It would have to be ground down.You can't just fix that with a blade, or maybe a coring bit or something?
