If this is in the wrong forum, please do move it to the right place.
Since Google pulled the plug on the Chromecast Audio, I decided to order a few different HDMI audio extractors to see how they would be as a replacement by using them in conjunction with a regular Chromecast. I only tested using Spotify, and not video sources such as a movie or a TV show, so there may be video lag introduced by these units.
I ordered 3 of them from Amazon, and have outlined my thoughts on them below.
I think most, if not all, of these units are re-branded Chinese units. Number 3 I'm unsure about since I haven't seen other listings of it on Amazon.
I ended up using the 3rd one, due to the noise-free analog out, clean look, and air vents on the side. I don't feel the need to spend any extra cash to get a lower noise floor.
- https://www.amazon.ca/gp/product/B07BHKHP7P/
- analog output has quite a bit of noticeable noise at loud listening levels
- optical output works fine
- did not test the coaxial digital output (but this is the only unit I bought that has a coaxial digital output)
- plugging or unplugging the HDMI cable will cause a pop in the analog out, and stop playback for a couple seconds (seems normal across all three units)
- HDMI output works fine
- no HDMI pass-through
- https://www.amazon.ca/gp/product/B07D7YR1NR/
- analog output has a very quiet noise at very loud listening levels
- didn't test optical out, but light was on and should be fine
- HDMI did not work on my unit, so wasn't able to test the HDMI pass-through either
- was able to get power via the HDMI port through my Chromecast... not sure if this is normal behaviour
- https://www.amazon.ca/gp/product/B07GZHPS6C/
- analog out has no noticeable noise (hiss from my receiver is louder than any noise from the actual unit itself)
- has air vents on the sides
- comes with 2 additional cables: 5ft optical cable, male 3.5mm to female RCA adapter
- has just HDMI input on one side (looks cleaner IMO)
- no pass-through option
