- Thread Starter
- #21
The most that bridging an Amp can achieve is increasing headroom, so enabling louder playback before the Amp clips.
Hoping for better low-volume playback is a pipe dream. There's no mechanism that could enable that
Thx
More power cannot possibly improve low volume sound (assume that's what you mean by 'lower levels') because the power you already have is not being used. You are just adding more unused power.I will. Bridging might not be the thing I need or want, but overall I want more power. My hope is that 2xC270 bridged will perform better, specially on lower levels, than one do in stereo. I will try with the 6 ohm Dalis and keep both eyes (and one hand) on heating. Again it`s all about what I hear, not what I read. The two C270 I have is in very good shape.
Thx. I
Hi, and thanks for reply.More power cannot possibly improve low volume sound (assume that's what you mean by 'lower levels') because the power you already have is not being used. You are just adding more unused power.
The caveat is if your amp(s) are already clipping at those low levels, but I think you would hear that and you wouldn't be able to turn up the volume.
Perhaps re-think what you are trying to achieve? Or can you explain it differently if I have misunderstood
Correct.Yes, by lower levels I mean lower volume. So by adding another amp, there are nothing to gain, like better dynamic, better bass, a.s.o.?
More power will enable louder playback. That's it.My idea, with more power, is that the speakers would preform better.
I fix the 6ohm problem by putting 2ohm 25W or 50W resistors in series with each speaker so the amp doesn't overheat. The sound is awesome for power and sound qualityHi, people.
I have two NAD C270 amplifiers (in very good shape) that I want to bridge. My loadspeakers are a pair og Dali with 6 ohm impedance. Can I use these speakers in a bridged setup without dangering the speakers or amplifiers? The load on the system will be normal, nothing extra.
Thx
A resistor is a linear device unlike inductors or capacitors so it has no effect on frequency response. That is what makes it such a simple way to solve a heat problem when dealing with speaker impedance issues to get the perfect power envelope for the amp keeping it cool and getting maximum power transfer to the speaker.. Try it out you will discover your speakers sound even better when the amp is running cool. Heat in the output stages of the amplifier transistors does introduce distortion, so cool is always better.Wouldn't that *significantly* alter the frequency response of the speakers?
When you buy a signal generator and it says "OUTPUT IMPEDANCE 50 OHMS" it doesn't matter what you connect to it. Its internal output impedance does not change! Same with an amplifier or any electronic device. It's output impedance is never altered by the load. Connect a resistor still 50 ohms...connect a capacitor or inductor or any combination the output impedance is not altered. it is always 50 ohms. The amplifier is the same, the load makes NO change to the amps output impedance.. So if you put a series resistor of 2 ohms from the amps output the output impedance looking back into the amp is 8 ohms (a common amp output impedance) plus the 2 ohms you added in series. It will never change dependent on the output load. It will however alter the overall system impedance dependent on the load. The laws of physics don't change because you have been told incorrect information. The C270 output impedance is 8 ohms. to get maximum power transfer the load needs to be 8 ohms. Any other value causes a poor power transfer issue, heating distortion to name a few.. I taught Electronics Engineering, Physics, Mathematics and Computer Science for 10 years. If I got it wrong then the entire University all my peers and hundreds of students got it wrong. So thousands of people are wrong and you are right...who do you think has it right?
Aah, the loudness effect due to a high impedance source feeding a load with varying impedance. A cheap way to emulate tube amp sound with SS amps, but burns part of the available power in the resistors.I fix the 6ohm problem by putting 2ohm 25W or 50W resistors in series with each speaker so the amp doesn't overheat. The sound is awesome for power and sound quality
Up to here this is correct.When you buy a signal generator and it says "OUTPUT IMPEDANCE 50 OHMS" it doesn't matter what you connect to it. Its internal output impedance does not change! Same with an amplifier or any electronic device. It's output impedance is never altered by the load. Connect a resistor still 50 ohms...connect a capacitor or inductor or any combination the output impedance is not altered. it is always 50 ohms. The amplifier is the same, the load makes NO change to the amps output impedance..
The output impedance of SS amps is not 8 Ohms, it's very low (say less than 0.1 Ohm). I think you misinterpret the recommended load impedance with the output impedance.So if you put a series resistor of 2 ohms from the amps output the output impedance looking back into the amp is 8 ohms (a common amp output impedance)
Correct.plus the 2 ohms you added in series. It will never change dependent on the output load.
No, see above.It will however alter the overall system impedance dependent on the load. The laws of physics don't change because you have been told incorrect information. The C270 output impedance is 8 ohms.
No, see above. Audio amplifiers are voltage sources, and the maximum source current defines the minimum load impedance. They are not designed for maximum power transfer which in audio is a relict from 70+ years ago, if it was used at all.to get maximum power transfer the load needs to be 8 ohms.
No, see above.Any other value causes a poor power transfer issue, heating distortion to name a few..
Ouch.I taught Electronics Engineering, Physics, Mathematics and Computer Science for 10 years. If I got it wrong then the entire University all my peers and hundreds of students got it wrong. So thousands of people are wrong and you are right...who do you think has it right?
