Lord Bobbymort
- Joined
- Apr 10, 2019
- Messages
- 37
- Likes
- 19
- Thread Starter
- #21
Just get a multichannel system, and upmix your music to more speakers
Less expensive to use what I have now than spend on multichannel
Nice! How'd you actually end up hooking it all up? What did you listen to? What was it like?Finally got around to setting up third speaker to create the Hafler Circuit. I am pleasantly stunned by the results.
Interesting, why do you say?If you toe the L and R speakers in, to cross in front of your listening position, it might work even better. Jim
I was, too, in 1971. My enjoyment didn't endure.Finally got around to setting up third speaker to create the Hafler Circuit. I am pleasantly stunned by the results.
Th speakers were already "toed" and the third speaker was at the base of the "triangle." While listening in the triangle, I was impressed. Stepping out of the triangle, the stereo image did not disappear and the room had pleasant sound where ever I went.If you toe the L and R speakers in, to cross in front of your listening position, it might work even better. Jim
I did that with my Duplexes for... quite a while, actually (and FWIW). I sat a few feet 'beyond' the focal point for the two coaxes' output.Th speakers were already "toed" and the third speaker was at the base of the "triangle." While listening in the triangle, I was impressed. Stepping out of the triangle, the stereo image did not disappear and the room had pleasant sound where ever I went.
Agreed! Especially in damped rooms. How do you implement? Ever thought of using a separate amplifier with volume control? I've also been able increase compatibility with most recordings/soundtracks by crossing over around 500hz.I had the Hafler Circuit for about two months. Every once in a while I disengage the third speaker just to assess if I still like it. I notice the room sounds hollow when the third speaker is not in use. Thus I am keeping the Hafler Circuit.
Did the OP find bliss with an Eno set up?
Right now I have Elac Adante AF61 as the left and right. The third speaker is a Energy book shelf speaker. I was considering getting another amp for the third speaker but grew concerned that signal might be out of time with the signal being sent to the Elacs.Agreed! Especially in damped rooms. How do you implement? Ever thought of using a separate amplifier with volume control? I've also been able increase compatibility with most recordings/soundtracks by crossing over around 500hz.
No chance of analog ever being "out of time." (Electricity is at the speed of light.) Keep in mind you must use a line-level pre-out to implement another amplifier. So a Y-adaptor on your pre is needed. Then simply connect your (negatively grounded) amp's +,+ terminals to the third speaker. Depending on this amp's impedance, 2 rear speakers may work best. Amp's +'s to speaker positives and then a wire connecting the two speakers' negatives together. You can also find used Lexicon 8 pre-amps with 2 pre-outs with volume control for each out.Right now I have Elac Adante AF61 as the left and right. The third speaker is a Energy book shelf speaker. I was considering getting another amp for the third speaker but grew concerned that signal might be out of time with the signal being sent to the Elacs.
There is an earlier post about protecting equipment. I would also do a search on the topic. You might want to experiment with a cheap amp.Curious about the haffler effect. Would this cook my NAD 3100 amp if I hook the two positives using a quadapter?
I had a Dynaco ST-80 that had this built-in. I ended up not using it due to the unpredictability and occasional odd-ball effect. The results are entirely program material dependent and not the least bit like true surround sound.I just watched a new video from Paul/PS Audio () regarding Brian Eno's suggestion to use a 3rd speaker connected to the positive terminals of your amp, placed behind, to play the uncommon audio from both channels, potentially playing audio not heard with a standard 2-speaker setup.
Does anyone have any experience with this? I'm really tempted to try it in my room, but need a bit of time around work and life to give it a shot.
I'm also wondering if there would then be any benefit to hooking up a 2nd speaker to the negative terminals. I'm guessing not in practice, but in theory there would be audio in both phase directions that are uncommon that would be played by having two speakers behind playing the positive and negative side separately.
I currently use a technics SH-AV22.Delay would totally work, and is MUCH easier to do today than when the Hafler hookup first came out. Not sure about bandpassing, I'd have to mull that over a bit. Maybe remove some of the low end if things got muddy, but I don't recall that happening.
When I did this in the early 80's, I used a separate integrated amplifier so I could easily fine-tune the relative level with its volume control. Still it was definitely annoying to not get the proper volume dialed in until the song was halfway over, and this was listening to vinyl so immediately restarting the song, while feasible, was not recommeded.
The reason the volume setting varied so much from one track to the next was that the amount and loudness of the content reproduced by the secondary speakers depended on how the recording was mixed, and often changed from song to song, and even within the song. One song I remember in particular was "Fat Bottom Girls" by Queen. The secondary speakers very clearly and fairly loudly reproduced Brian May's isolated harmonizing vocals at the beginning of the song ("Aaaaaaaaaaah you gonna take me home tonight?"). Sometimes I'd turn the main speakers way down for that part just for fun. Brian May has a beautiful voice... but he just happened to be in the same band as Freddy Mercury!
One of the reasons I moved from the Hafler hookup to polydirectional speakers is that, with proper set-up, ime polydirectionals (including dipoles, bipoles, quasi-omnis, and omnis) can do a good job of conveying the venue's spatial cues with no need for fine-tuning from one mix to the next.
(Along the way I also tried the Carver Sonic Hologram Generator and a similiar device called the Omnisonic Imager, as well as with a DIY knock-off of the Polk Stereo Dimensional Array. All had their upsides and downsides.)
Really, did someone do some custom mod's to the amp for that?I had a Dynaco ST-80 that had this built-in. I ended up not using it due to the unpredictability and occasional odd-ball effect. The results are entirely program material dependent and not the least bit like true surround sound.
