Breeze Audio DU-D8 help needed.
Vintage57
Ontario, Canada
I received a new Breeze Audio DU-D8. I purchased it with the intent of converting the output from my Mac Mini USB to my DAC with any of the output choices.
Specs are as follows
Brand: breeze
Name: XMOS Digital audio system
Origin: China Foshan
Input: USB data cable
Output: coaxial, fiber optic, IIS (RJ45 Ethernet port), AES / EBU
Bit depth: 16bit 24bit 32bit
Environment: Windows / MAC / part of the mobile device (phone, tablet)
My problem is the Mac Mini recognizes the output and I can click on it in the settings menu however at the DAC there is no signal.
I tried both fiber optic and AES/EBU.
Any suggestions?
Thanks
gcann
Brand: breeze
Any suggestions?
Thanks
Hi, long shot, but have you ever found a solution for this issue?
gcann
Found it! It was the wrong bi rate in the audio midi app.
