boXem Arthur 5523/E1
Hey, good to see you finally opted for the Purifi amp and did not buy the old heating appliances off the class-A-I-play-this-louder-for-you salesman.
Hello,
Your Arthur power amplifiers (based on the ET9040AB module) have been running with my high-efficiency speakers and Teac UD-701N for over two weeks now.
I am delighted with how your amplifiers perform in my system; transparency and precision are the standout qualities compared to my previous Class A amplification.
The control over the dual 8-ohm Altec 3156 drivers per speaker is impressively precise; the Radian midrange and Fostex compression tweeter are never harsh, and they even reveal details that were well-hidden with my previous setup.
I even went so far as to test adjusting the low-frequency crossover point for the Radian driver on its large Iwata horn—while, of course, readjusting the high-frequency cutoff for the Altec woofers to 250 Hz.
The Radian’s response curve on the horn is perfectly linear across the 250 Hz to 7,500 Hz range.
The woofers—now with adjusted impedance correction—operate strictly within the 40 Hz to 250 Hz range (down from the previous 380 Hz).
We can confirm that, in this optimized configuration, the use of high-precision capacitors in the midrange section is crucial.
I can vouch for the fact that your Arthur amplifiers truly amaze many listeners with their sound reproduction; rest assured, Class D will no longer be viewed the same way.
You paid for the best from Purifi and that's what you got. I'm confident you would have the same subjective result using 1ET6525SA, but that's not the point.
I couldn't live with those horns (and the small TV lol) but interesting what you have lined up for listening there. Wish you a lot of fun with it.
I’d like to mention the use of these same Boxem amplifiers in a friend's system; we received our units at the same time.
His setup consists of a Nubert streamer/DAC, an Atma-Sphere MPA tube preamplifier, four Arthur amplifiers (two per speaker), and B&W 800 Matrix speakers.
Previously using Pass Labs X600.5 monoblocks, my friend feels no sense of compromise after switching to Boxem.
The setup requires two Boxem units per speaker (one for the two woofers and one for the midrange and tweeter).
When set to medium gain, the Boxem units deliver exactly the same volume level as the Pass Labs amps.
Beyond the physical space savings (9 kg per pair of Boxems versus 70 kg for the Pass Labs) and the elimination of heat dissipation issues, the sonic character remains very similar, despite some subtle differences in reproduction.
One happy new owner!
B&W 800Matrix
Personally, a sound performance that evokes deep emotion matters more to me than the visual aspect—which, while perhaps open to debate, is perfectly acceptable to me.
Tastes differ from person to person, but a sound performance that stirs deep emotion is something we all share.
Absolutely. I never had horns. Maybe I could ignore them because of their performance.
