boXem Arthur 5523/E1
Ursulou
Hello,
The Boxem Arthur ET9040AB units have been installed in my hi-fi system for three days now.
After a difficult choice between Audiophonics, Apollon, and Boxem, I opted for Boxem: beautiful build quality, neat internal wiring, a dedicated XLR input (no RCA/XLR switch), high-quality XLR and speaker connectors, and a quality chassis—all manufactured in France.
It is important to specify the exact configuration:
Teac UD-701N player/streamer/DAC/preamplifier, paired with a small external Vmillion clock that has been perfectly implemented (using a Chinese linear power supply set to 9V and, crucially, a custom-made power cable between the clock and the Teac based on aerospace-grade wire—far superior to very expensive hi-fi brand cables—along with a clock-to-Teac interconnect cable with precise impedance).
I will come back to the Teac's specific and crucial settings later.
The 230V power cable for the Teac and the Boxem units is a Supra LoRad 2.5 MkII—a simple, affordable, pre-assembled cable where the composite shielding foil is connected to ground at the wall-plug end.
Each mains plug/cord respects the phase orientation corresponding to the Boxem input, the standard accuracy of which you confirmed to me.
Each Boxem unit is connected directly to a wall outlet; only the Teac is connected to the filtered section of a power strip.
The Teac's XLR pin setting is configured for Pin 2:
Since the boXem Arthur power amplifiers adhere to the modern standard (Pin 2 Hot), you must keep the TEAC set to Pin 2 Hot.
This setting ensures that the final acoustic phase is perfectly aligned with the electrical phase of the passive crossover and my speakers.
The TEAC unit is connected via two 5-meter Galileo XLR cables (factory-fitted with XLR connectors).
Each amplifier is mounted directly onto the speaker cabinet (dimensions: 150 x 80 x 60 cm; constructed from 25mm particleboard with additional 25mm reinforcement bracing on the front, top, and rear panels—totaling 50mm thickness—weighing approximately 100 kg).
Anti-vibration treatment beneath each amplifier unit employs a spring-mass-spring configuration: a 15 kg limestone slab (40 x 30 x 5 cm) rests on supports made of agglomerated rubber particles.
This system drastically reduces the transmission of vibrations from the speaker cabinet to the electronic components.
Even the passive crossover—located next to the amplifier—is decoupled from the speaker using this same mass-spring system, maintaining a minimum 1:3 mass ratio between the stone slab and the component being protected (a 4 kg stone for the 1 kg crossover; a 15 kg stone for the 4.5 kg amplifier).
The settings on the Teac UD-701N played a crucial role in the resulting sound.
The Teac’s XLR outputs were initially configured for Pin 2 to drive my robust Class A monoblocks.
The converter settings had a significant impact on the sound.
Teac’s proprietary Delta-Sigma conversion really needs to be fine-tuned for each specific system.
The internet router is positioned one meter away from the Teac, connected by a short Audiophonics RJ45 cable with a network switch in between.
In my specific setup, the best conversion settings were "Multibit" mode with "Upconvert" turned off.
The clarity achieved with this configuration is evident in the precision of the vocals, the crispness of piano notes, and the spatial imaging of instruments and voices; without this precise setup, vocals lacked definition and receded into the background, while piano notes lost clarity and the tonal accuracy of other instruments was diminished.
This specific configuration—tailored to the Boxem Arthur 5523/E1 setup—allowed me to fully unlock the intrinsic qualities of these amplifiers.
Listening impressions:
Comparing these Boxem amplifiers to my Vincent SP-991+ monoblocks—which weigh 37 kg each—feels like a generational leap: it is like moving from a hard-to-tame naturally aspirated V8 engine in an old chassis to a turbocharged V6 in a highly engineered chassis that combines precision, speed, and thrills!
The expansive—and sometimes overpowering—bass of Class A gives way to a much more layered and precise sound with the Boxem Class D units; the nuances of various percussion instruments can now be appreciated in greater detail. While the tactile sensation of hands striking percussion skins might give Class A a slight edge, this is counterbalanced by the crisp control over instrument resonance provided by Class D.
The vocal "warmth" characteristic of Class A takes on a different quality with the Boxem amps: the precision regarding subtle sounds—such as sibilance and mouth noises—reveals sensual details in female vocals that were less distinct or present with the Vincent units (though the quality of the loudspeakers and the passive crossover design also play a role here). In this one specific regard, I really appreciated the GaN amplification of the Orchard Starkrimson25s; they held a slight edge in the tonal accuracy of a brush stroke or a timpani hit, with the sound springing forth from a pitch-black background of silence.
High-frequency details are much more present, defined, and precise with the Boxem amps than with my Class A unit—likely enhanced by the different dynamic range and control over the bass drivers.
Boxem gain settings:
Whether it was Audiophonics, Apollon, or Boxem, they all recommended the Purifi 1ET6525SA modules.
They were all misled by a high-sensitivity system (over 101 dB): I knew that my Altecs—rated for 250W—have stiff surrounds and demand a significant amount of power from the amplifier; previous tests with amps featuring inadequate power supplies had yielded very mediocre results.
The Boxem's medium gain setting allows me to comfortably push the Teac's volume past 75% for loud listening—even on a track with very low Replay Gain streamed via UPnP from Qobuz.
The Boxem's high-gain setting produces no hiss or unwanted noise on my midrange horns; while this setting initially seemed to offer a more open sound, it could come across as somewhat "harsh" or fatiguing at high volumes during extended listening.
In conclusion, the Boxem amplifier demonstrates a better overall balance than the other electronics I have tested—though, admittedly, I haven't tested everything.
Every piece of equipment has its strengths and weaknesses, but for the moment, Boxem represents the best compromise among the amplifiers I have tested
PS:The passive crossover was tuned based on measurements taken from each driver (two reconed 250W Altec 3156s; a Radian 745DPB8 midrange driver on a large Iwata horn, vertically aligned with the Altecs to maintain vertical and axial acoustic alignment; and a Fostex T900A tweeter).
The crossover performs three main functions: first, impedance correction for the two Altecs;
second, frequency separation between the bass, midrange, and treble sections at 380 Hz and 7,500 Hz;
and third, attenuation of the Radian midrange and tweeter output levels to match the 101 dB sensitivity of the two parallel-wired Altecs (these attenuation levels are fine-tuned according to the room's acoustics).
Placing the connection boxes close to the passive crossovers allows for short (60 cm) speaker cable runs, fitted with Mundorf Z-plug soldered banana connectors.
The passive crossover connects to each section (bass, midrange, treble) using cables with specific characteristics (silver-plated copper for the bass, and Nordost Heimdall flat copper for the midrange and treble); the only remaining upgrade in this area will be to separate the bass section from the midrange/treble section within the crossover, using distinct cabling between the connection boxes and the passive crossovers.
"Factual errors"? I don't understand what you mean; the automatic translation must be inaccurate. Errors did indeed crop up when translating back into French, but I have no choice—my English is limited.
I would also like to add that I have no financial interest in Boxem and that my comment is sincere
No, it has nothing to do with translations. For instance:
This is just untrue. A stiff surround doesn't matter. If the speaker is high-sensitivity, it will not need much power for a particular SPL.
The misleading thing here is actually the sensitivity number. Since you use these woofers for bass and midbass mostly, this number is rather optimistic. Below 100Hz, the sensitivity drops fast. When you linearize this with the crossover, the whole range up to 380 Hz will be left with about 95dB or so. Still respectable, but not 102 dB.
I'm sure that is the case. They are mighty fine amps.
The resonant frequency of the 3156 is 38 Hz; the two Altec units here are housed in an ideal 500-liter enclosure, and the sensitivity of a single unit is 98.7 dB/W/m—resulting in 101 dB for the pair wired in parallel.
Consequently, attenuating the mid-range and high-frequency drivers to match this 101 dB/W/m level is highly appropriate. Moreover, the sound quality in this configuration is excellent—something that wouldn't be the case if the sensitivity were only 95 dB, as you suggested (that would result in a distinct imbalance).
However, the Altec units' low-impedance dips—occurring at their low resonant frequency and near the 380 Hz upper crossover point—would explain the difficulties I've had driving these speakers with many other amplifiers; a problem that does not exist with the Boxem.
I will try to post the response curve for the Radian 745DPB8, perfectly matched to its large Iwata horn; it is exemplary across the 380 Hz to 7,500 Hz range.
The linearity across the entire audio spectrum is excellent thanks to this highly optimized crossover design (though this isn't really the main topic here, as I am reporting on the performance of these amplifiers in my system).
I apologize for not presenting a batch of measurement curves or supporting data for comparison; I live in neither a laboratory nor a recording studio.
Furthermore, I do not own any measurement equipment, for which I also apologize.
I am well aware that our ears and our sensibilities cannot be measured; I can only share our listening satisfaction and our own judgment based on the accuracy of the timbres reproduced by this electronics setup. In any case, I’ve owned various hi-fi setups and listen to a lot of concerts and other musical performances; our ears are satisfied when it sounds good.
I can now say that our system has improved significantly and brings us a great deal of enjoyment—and isn't that what matters most, even if it can't be measured?
I managed to retrieve the measurement curve for the Radian 745DPB8 compression driver on the large Iwata horn; it took several attempts to fine-tune the transition between the Radian driver and the large Iwata horn to achieve this result, which translates into a magnificent listening experience.
Ideal for what? Tuning it high will yield a distinct bass hump (and additional group delay), but you will preserve some of the efficiency, at least; tuning it will eat up your efficiency, but it will have very good extension and would definitely compromise on maximum output. There is no ideal; every choice is just a different compromise.
Really, the amp is the least interesting part of your system ;) We pretty much know how it performs based on many other amps with similar modules. They are generally all fine and are fully transparent, as are probably all the other amps you tested. If you do not properly level-match these when comparing, you will be fooled by the level differences of orders of magnitude more than by any supposed differences in the amps (as long as you stay within their respective limits, which at these sensitivities should not be an issue). So, generally, we take these kinds of subjective impressions with a grain of salt if no proper basic control was taken into account.
That is very nice! Got any off-axis measurements? Would like to see the full speaker, if you have that data?
Luxembourg I think
Yes, a translation error:
the cases are manufactured in Metz (France), and the amplifiers are, of course, assembled in Luxembourg by Boxem.
Thanks for the correction.
No, we don't have the measurements for the complete speaker system.
And yes, devices from other manufacturers using the same Purifi Eigentakt ET9040 modules and power supplies might well sound very similar to Boxem units.
In any case, there is zero noise or hiss through the Iwata horns when using the Boxem high-gain setting (29.5 dB).
Their specific implementation of the op-amps is apparently the result of their own research; it is also worth noting that Boxem was the one to pioneer these gain settings—other manufacturers simply copied the idea. Boxem can correct me if I’m wrong.
Yes, there are a few things that the Boxem amps have that you pay a bit extra for, besides the very nice (and small) enclosures. Custom input boards, nice gain control, and a good auto-standby feature.
