Boxem are best.
Correct, reason why i went for competition that offered , for same integrated module, a nice looking case ... To my eyesWhat has an appeal to you is overloaded to me. Tastes are different, luckily for us![]()
Hummm ... Again that's your own thinkingBoxem are best.
Define better. Objectively.Hummm ... Again that's your own thinking
Appollon audio offers MUCH better amps and choices at similar price tag
For those of us who like bigger stuff at the "traditional" full size and with full cooling abilities?Hummm ... Again that's your own thinking
EasyDefine better. Objectively.
I don't thank you for being rude and insultingHe's probably not going to be able to define methodically how they are better when he can't even correctly spell the amp manufacturer name? Trolling is easy. Proof is hard.
Boxem amps are at an entirely different level. Most 3rd party Hypex/Purifi builders don't thoroughly test their designs until a problem is discovered by a reviewer months later, after they have been selling them to customers. That doesn't happen with Boxem because quality and testing is job #1.
The truth?
No, Appolo don't make better amps, they make bigger amps for their premium line that LOOK nice, that LOOK close to what one pays for similar traditional stuff, material is the correct, BUT...
Painted???
The golden traditional rule for hi-end entry prices (from 5k euro and up for amps) is anodized, brushed alu. Period.
And not only that, but anodising had to keep a consistent shade of the color (we're talking nightmares if you see the process) .
Nothing can beat its premium feeling.
Of course no differentiator whatsoever for the purifi stuff soundwise, other than power vs time cause of the cooling real estate, heatshinks, etc.
There's no bells and no whistles! ( LOL- I hope that translates correctly.)
Easy
As a consumer i would look for exemple at Arthur 4216/e2 @ 1860 euro stereo with 2 Purifi 1ET6525SA Eigentakt and one hypex smps 1200 as a single power supply / all fit in a little aluminium box and a front panel in color .. measurement and power wise, its perfect... But its not ''sexy'' enough for the price ..it looks basic ..form factor small box
Still as a consumer i keep looking on net and fall on other offerings ..other brands that implement the pufiri module 1ET6525SA..
Example the appollon audio double mono that uses the same modules at exactly 1890 euro too and offer additionals options if needed, worth to mention there's double power supply..
Performance wise ..these two amps play the same game
Case :
appolon brings nicer looks with a more elegant aluminium case and form factor ..12kg ..there must be some space inside that box , air would circulate i guess.
Amp with not move with heavy câbles attache to it
Boxem Arthur : 4.6 kg ... Form factor compact inside , getting warm?
I'll list one objective advantage for appollon:
4 gain settings and 2 power supply Versus 3 gain settings and one power supply for stereo for the boxem
So if right now i have to purchase a purifi and throw 2ke in an amp , appollon attracts .. boxem looks expensive in comparaison
Performances are similar, outside hearings capacity ... They will deliver the power to move speakers
When you study the measurements of various Purifi 1ET6525SA offerings from different third party builders you find:
1. Dual power supplies make little to no difference in sound quality while significantly increasing energy use and heat.
I would never buy a dual PS 1ET6525SA amp. It's never worth the extra cost.
2. You don't need 4 gain settings. Typically, you use the high gain setting when used with an AVR. In addition, after trying low gain I discovered high gain was usually more engaging dynamically in my system. Having more gain settings offers another point where hardware can fail and is a waste of parts in my view.
3. The Boxem Purifi never gets warm. It also offers plenty of weight to hold cables in place. Suggesting otherwise indicates you likely have never used the Boxem?
4. In most cases, less is more. The amp lasts longer when only a single PS is used and the quality of the gain stage has nothing to do with the number of settings and everything to do with the design and testing that went into it's creation. Boxem's Purifi gain stage is the best in the business.
5. At some point, if you're looking for amp quality; measurements matter more than any specific look of the case.
Yeah, but non one cares about your home since it's not the subjectMy home is in what they call mid century modern style, and the furniture is similar with designs from e.g. Arne Jacobsen and Poul Kjaerholm. Why spoil that esthetic with retro designs like Accuphase or Luxman? Less is more.
It provides context for my esthetic preference.Yeah, but non one cares about your home since it's not the subject
‘Premium’ design? Personally not a fan of 70’s design and prefer the understated Boxem aesthetic but that is of course purely subjective.
