boXem A 4216/E2 Stereo Amplifier Review
Rate this power amplifier:
    Votes: 2 0.7%
    Votes: 1 0.3%
    Votes: 30 9.9%
    Votes: 270 89.1%
This is a review and detailed measurements of the boXem A 4216/E2 stereo balanced amplifier based on Purifi 1ET6525SA class D module. It was sent to me by the company and costs €1,160 (USD $1,350).
While not built out of billet of aluminum and such, the 4216/E2 still manages to look unique and attractive. The case is plenty big and airy and in use did not even rise above the room temperature. The protection circuit is very robust and did not care how many times and how much I pushed it into clipping. It would keep going without shutting down.
Was happy to see trigger support for automatic turn on with sources that sport the same:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D Power balanced back panel review.jpg
While there is a standby mode, I was surprised there is no hard On/Off switch. Otherwise, the binding posts are solid and high quality. There is a high and low gain which I appreciated especially since even the low gain mode can be driven to max power with nominal 4 volt input.
boXem 4216/E2 Stereo Amplifier Measurements
I started the measurements with low gain:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain measurement.png
Distortion at -120 dB is well below threshold of hearing in all cases. SINAD therefore is noise limited (see later). This is top level performance:
High gain has a very slight penalty of about 2 dB as reflected in SNR:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D SNR measurement.png
As a reference, my requirement for above is 96 dB! Given the large amount of power available on tap, max SNR shoots way up:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D SNR Max Power measurement.png
Frequency response is nice and flat, with no load dependency:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D frequency response measurement.png
Crosstalk is incredibly good:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D crosstalk measurement.png
Multitone and dual tone IMD tests show excellent results:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Multitone measurement.png
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain 19 20 intermodulation disto...png
While we have a number of excellently measuring amplifiers, not all of them are powerful. The boXem is:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 4 ohm measurement.png
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 8 ohm measurement.png
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 4 ohm max and peak me...png
There is not much variation in power either as we go lower in frequency:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 4 ohm 40 Hz measurement.png
You can see the same in our "FTC like" power vs frequency:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 4 ohm FTC measurement.png
Can't explain why it produces more, rather than less power at 20 kHz! It is reflected the same in our power sweeps vs frequency:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power 4 ohm vs frequency me...png
Distortion rise with frequency is managed quite well especially for a class D amplifier.
The amplifier cruised through my reactive stress load tests down to whopping 2 ohm!
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power Reactive Voltage meas...png
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain Power Reactive measurement.png
It doesn't quite "double down" but close enough.
Amplifier is ready for party on power up:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D low gain warm up measurement.png
There is a small chance of turn off pop:
Boxem A 4216 E2 stereo amplifier Purifi 1ET6525SA Class D power on off noise measurement.png
The boXem 4216/E2 is an attractive amplifier both in looks and performance. It produces everything you want in a power amp: lots of clean, absolutely clean power with very low noise and distortion. The value is surprisingly good for a product assembled and sold in EU. A feather in the cap of residents of that part of the world.
I am happy to recommend the boXem 4216/E2 amplifier.
Awesome amp! Thanks for the review.
Inside picture courtesy of boxem's website.
An excellent piece of gear, robust and tests very well. A premium price: $2000 Australian before freight, yet worth over double that price. Well done boXem! Thanks Amirm.
Sweet 'Speakon' is an option. All my wires are DIY Speakon now.
This is really tempting. Alright so I haven't kept up on high powered amp prices the last year or two.
Without redirecting the thread, just more or less thinking out loud, what else is there for this price with at least this much power? USA = Buckeye?
Quality will out, won't it? Start with the excellent Purifi modules, add a Hypex (?) SMPS, and bring in Boxem's meticulous design and craftsmanship, and you get something that puts all those multi kilobuck amps made from solid billets of machined aircraft aluminum to shame. I own the Purifi 1ET400a's which I assembled from parts, and it's just stayed there. done everything expected of it and not called attention to itself at all. Almost like a middle child or something.
As always, great review, Amir.
Anyone know how the USA crazy tariffs will impact price of Boxem A 4216/E2 if ordered for USA delivery?
Between Purify, Hypex, and THX AAA, are amps pretty much a solved problem like DACs?
I would rather own Boxem amp than Buckeye after owning both.
Wasn't trying to say don't buy Boxem. Just trying to understand if tariffs would kick in. And how much?
The handshake tariff agreement is 15%.
I got lucky: At the time I purchased mine (2/22/2025) there was no tariff.
Will hit us either way since US amp builders will still pay tariffs on purifi parts. From what I can tell the rate from EU / Denmark is 15%.
Aside from that this amp looks pretty ideal!
