Geert
- Joined
- Mar 20, 2020
- Messages
- 2,313
- Likes
- 4,741
Read Toole's research. Or do you have better study material?To read Toole's opinion?
It's not that Toole completely missed that aspect. On the contrary, it was a topic of its own in his research. Discussed in length in https://www.audiosciencereview.com/...nophonic-vs-stereophonic-timbre-change.15829/.
Because one might like it.
For example the wider soundstage and more enveloping spaciousness of wide-directivity speakers in untreated rooms, or the time-delayed signal-correlated distortions from vinyl playback, good old analogue "warmth" or even tape hiss, the more distant perspective of a BBC dip, the "darker" and more forgiving sound of a treble roll-off, etc.
Anything that may produce a presentation which increases the enjoyment of one's listening experience. This is of course a matter of personal taste and in some cases it may have to do with listening habits (older audiophiles having grown up listening to a particular type of presentation which they still prefer).
Well of course one might like it, but that's axiomatic. One might like to feel enveloped by the reproduction of a single-miked chamber music concert too - the "documentary" style recording you noted above. The type of music is irrelevant. The entire premise of this site - and for example Floyd Toole's "circle of confusion" concept - is that sound reproduction should be about fidelity to the source.
And if you've always had colored equipment, and you've never pursued maximum fidelity/neutrality, you don't know what the source is supposed to sound like, so how do you even know what coloration, if any, you actually prefer?
All good questions. But some people still choose coloured equipment.
Have you guys EVER been to an audio show? or you're sitting behind your computer babbling? Have you ever been to a dealer with a friend? Literally EVERYONE has a different opinion about what sounds GOOD to THEM! It's 100% subjective when it comes to speakers. Same room, same equipment, same speakers, one hates it, one loves it!
Same goes with headphones! Some love headphone X, some HATE IT, some love headphone Y... while electronics gear is more consistent across the board.
Actually, while there is certainly room for subjective preferences, we have good research that shows the vast majority of people prefer the same sound under blind conditions, and that is the sound of a speaker with neutral on and off axis measurements.
Also, research shows that the room doesn’t matter that much either. The speakers that measure the best are the most preferred in all rooms.
Of course, B&W speakers are some of the most visually appealing speakers(IMO), and have a good brand value, so I would expect them to do better in sighted tests than they do in blind tests.
Or the BBC dip could be by design...I have these speakers. I've had to tweak an analog graphic eq to get voices to come forward enough to sound proper. Sounds great now.
With respect to the crossover at 4KHz....I've found the circuit diagram for the crossover on this speaker. It is all passive first order L-R and R-C circuits. Based on the values supplied by B&W, I've calculated the -3dB for the low freq driver to be 943Hz (1.35 mH and 8 ohms). The R-C circuit -3dB is accurate for 4KHz xover. The data you've published is not consistent with an f3 of 943 Hz and that is not consistent with B&W's published xover of 4KHz. Your published data is consistent with a 1KHz or so filter although it is a bit difficult to be sure since the driver's FR is not flat. Since I must trust your data, I'm left with the conclusion that there is either some design flaw or there is something going on with the response of the low freq driver that forced B&W to change the value of the inductor to 1.35mH.
I'm considering getting a spare xover and modifying it. I can then measure fr and phase with REW as a function of different inductor values. Of course, I'll need to change the cap on the HF driver as well. This might be a bit of work. I've not opened these speakers up yet.
Thoughts?
Seems that one should be looking for a speaker that doesn't have coloration.
I have the 804N and have worked on the EQ with REW quite a bit. If they are too flat you lose the realistic atmosphere or "you are there" sensation that I think is the magic the B&W curve gives.Good advice. I'm a tinkerer, so it is in my nature to figure things out and attempt fixes. I like learning this way.
I like the sound well enough. In fact, I was happy until a friend said they were too "Laid back". So I played with .EQ-ing the 1-5 KHz band. Getting the fr flatter really improved the sound for me and for my golden ear friend. I do like the new sound. I have had other speakers in the system and hated them almost instantly. Always come back to these.
That graph you’ve uploaded is a clear proof of a good performing speaker. It’s a shame they stepped away from there.As Mr Dallas wrote (...I wonder how my 805Ns from 1999 would measure on Amir's Klippel...), similarly, as a very long time owner of the B&W 801 S2 (w/S3 x-over mod), I've searched for spinorama data for the 801 S2 and/or S3 but have found nothing. Has anyone found or generated any such data since the Stereophile review of the 801-II in Dec 3, 1995?
Fig.4 B&W Matrix 801, anechoic response on tweeter axis at 50", averaged across 30 degrees horizontal window and corrected for microphone response, with the nearfield woofer and port responses plotted below 1kHz and 600Hz, respectively.
It seems there are many references to the B&W of old and such a venerable design for it's time, yet no one has acquired a full(er) data set on this grail (holy or otherwise)?
