I have two Paradigm V12 subwoofers, and both produce an unusual fluttering/vibrating sound with an unpleasant tone during strong low-frequency effects in movies.
I can also reproduce the sound using the subwoofer test provided in the Paradigm control app. I recorded that test here:
I have already emailed Paradigm support and sent them the video, but I would appreciate opinions from experienced owners and installers while I wait for their response.
Because both V12 units exhibit the behaviour, I am trying to determine whether this is likely to be:
- port turbulence or chuffing;
- the driver reaching excessive excursion or the amplifier/limiter intervening;
- a loose grille, trim piece, amplifier plate, foot, cable, or nearby object resonating;
- a setup issue involving gain, EQ, room correction, phase, or the app test level;
- or a fault that needs service.
Has anyone heard this particular fluttering tone from a Paradigm V12 or another ported subwoofer? Does the video suggest airflow noise, mechanical vibration, driver distress, or something else?
I have two V12s and hear the issue from both during low-frequency events. I can provide additional details about settings, placement, AVR/processor configuration, and room correction if that would help diagnose it.
Thanks for any suggestions.
