Bookshelf Speakers Amp Recommendations?
Steve Rogers
It sounds like you want an integrated amp as you want a remote and sub out and are budget constrained. Why not go to a local shop that sells your dali and take your fosi with you. You can then compare it to an integrated amp with these features and in your budget playing at similar volume (try to volume match as much as possible) and see if you hear a difference. If dealer is prepared to do this blind for you even better.
