Strangely, everything is perfect for him, even the "new" MQA.He claims not to, and I see no reason not to believe that.
Allow me to be skeptical.
If you have a friend working at Bluesound, could you please ask why they don't care fixing this long lasting bug ?A friend is at Bluesound.
... curious to see if they -finally- fix the Bass noise issue.Performance improvements
Nope.Hi.
I have a question about how the Icon updates the software and it is that the first time I started the device when I installed it on my sound system and with the last update 4.8.17 yesterday it happened that it did both updates correctly but at the same time finish, the light turns red and the screen turns off. According to Bluesound, you have to disconnect from the power grid for 30 seconds and reconnect if this happens, but it doesn't seem normal to me to have to do this after each update. I have asked Bluesound and they tell me that it is okay to disconnect the Icon from the mains after the device is updated. Do you have to do this every time it is updated?
I think you may be mixing up a few things. I have gone through a number of firmware updates on a few units including my new Icon. There is nothing in the Bluesound instructions about being required to disconnect the unit after an update. Bluesound will say it is OK to unplug it AFTER the update finishes, and definitely not during the update. If you have questions if the update installed, look in the settings to see the version number. If it is not the updated version you may have to simply re-run the update process, but I have not seen this as a common issue.I have asked Bluesound and they tell me that it is okay to disconnect the Icon from the mains after the device is updated. Do you have to do this every time it is updated?
This update applies to all Bluesound, NAD, and PSB players except the NAD M66.BluOS 4.8.17. Released January 28, 2025
• Performance improvements and feature enhancements
WHAT’S NEW
DIRAC: Support C379
DIRAC: OEM Provided Updates
Dolby: Support M10v3
MQA Qrono: Codec Update
WHAT’S NEW
DIRAC: Support C379
Let's hope we can disable it.It is only a matter of time before other devices receive the new MQA technologies.
This stuff isn't necessarily just old MQA and may not be a problem at all. Some of the older Nodes with poorer SINAD may even be improved, regardless of the controversial claims.Let's hope we can disable it.
I don't want to be forced to get rid of all my Nodes and PowerNodes.![]()
Of course.Just as I wouldn't buy anything with QRONO without more evidence of what it really does, I wouldn't expect horrors from it being installed without evidence eiteither.
Let me be my own judge on that, please.QRONO can't be that bad. I've only heard positive reactions so far.
