Can you run some more tests with Multitone tool ? That SINAD looks great and the red seems to eliminate mains noise??Trying to measure my Icon and found that it depends on AC, no matter XLR or RCA out.
Red - with AC Filter (Powerquest 2), green - direct.
Checked the same with Wiim Pro Plus, and there are no differences for both filter/no filter.
Seems not to be audible but...
That’s neat. I have a version of tha unit and had sent it into Amir.Yes, red one is via Audioquest filter that reduces 50 Hz AC noise and its harmonics.
www.audiosciencereview.com
I use Scarlett 2i2 3gen, so it's just for fun as both Icon and Wiim have better SINAD.
As a newcomer to ASR, it's disencouraging to see claims like these with no real backing by evidence. In my opinion ASR should rely 1) on technical analysis 2) on ABX testing to verify claims. Subjectivity is okay, but should be clearly stated. As I have read this thread, a newbie like me will get the impression that this streamer and Qrono is something special. That is yet to be verified.MQA QRONO will make the difference. d2a contains a different filter.
There are already reports of this in some YT videos. However, I will deliberately not link to them here.Unless there is some evidence that this makes a beneficial and audible, difference
Dirac Live will also be able to help here.but a bit 'high' or 'sharp'
Part of Home Theatre Grouping is hardware or chip set based. <-- What is the difference here?
And of course the Icon could also play back a front stream, even if it cannot decode it itself. Technically, this should not be a problem under BluOS.
Let's just give it time, similar to the upgrade for older nodes with Dirac Live.
No. There was once a statement that they 'wanted' to retrofit this via an fw upgrade.
I have just remembered a report on this: Link
