- Joined
- Oct 25, 2019
- Messages
- 12,231
- Likes
- 17,331
Time out . Only come back with something constructive .Your a idiot
Like the functionality of the Icon but the looks disappoint compared to the Eversolo range - even the DPM6 looks considerbaly better. Shame the design is not in the same league as the functionality ... Hoping them or Wiim bring out a higher range better looking one with a alrger screenSize comparison with Wiim, the Icon display is useable at listening position for me, Wiim not so much. Both are handsome to me.
For me, it's primarily the sound that counts and the Icon has a clear advantage there, partly because of Dirac Live.
Nothing. In fact it's much worse when you think about the manual adjustment possabilities the WIIM has. And then especially the bass management capabilities with automatic time alignment, crossover including bypassoptions and so on...Haven't seen any measurements and dirac isn't available last I checked, so what makes this sound better than the competition?
Let's assume that the engineering has worked properly.Haven't seen any measurements and dirac isn't available last I checked, so what makes this sound better than the competition?
Maybe sounds better due to MQA QRONO.
The first experience reports from those switching from Wiim & Co. probably point in this direction.
Measurements are already available, see also the Technical White Paper![]()
Yes.or did you just mean d2a?
What do you end up doing for this?Anyway, I have a WiiM Ultra which has a mild ground loop with my active speakers. I am going to try grounding it with a separate cable.
You will achieve better results with Dirac Livebundled PEQ
What sample rate does Wiim use for post-processing?
According to the measurements, QRONO seems to show its full potential at higher sample rates. I assume that the Icon, like my M33, also allows post-processing at 192kHz.Even recording 24/96 and no EQ enabled the WiiM downsamples to 48 kHz.
