Bluesound Powernode Edge Streaming Amp Review
Rate this streaming amplifier:
    Votes: 11 8.5%
    Votes: 57 43.8%
    Votes: 52 40.0%
    Votes: 10 7.7%
Unfortunately that's not how Dirac licenses work. The licenses are attached to a device.
Well, that's an interesting question.
What does the license cover, actually ?
I guess not the filtering part itself (FIR and IIR filters are nothing secret) but the algorithm and software to measure and compute them.
So if you pay for this software, why wouldn't you be able to use it for several devices, which may be thought as part of the same system ?
Reading the Dirac EULA, things are not black or white either:
Dirac grants you a non-exclusive, non-sublicensable, limited license to use the object code version of the Software solely in connection with your personal use on your own personal hardware and related equipment and for the purpose of optimizing sound reproduction. The Software shall not be used for any other purpose.
For Software included in the Dirac Live Room Correction Suite (“DLRCS”), the following terms and
conditions apply. You may (a) install and use the DLRCS on a single computer (or similar device); or install
and use the Software on a network
, provided that each person accessing the DLRCS through the network must hold its own license to the DLRCS; and (b) make one (1) copy of the DLRCS for archival purposes,
provided that such copy must contain all of the original DLRCS's proprietary notices, shall be in object code
(that is, not in human-readable) form, and shall remain Dirac’s intellectual property.
Sounds like this excellent product might be getting a "Dirac Ready" compatibility update (license would still cost additional $$)...
From Matt Simmonds (Bluesound Brand Manager):
"...Our plan is to make Dirac Ready available on the hardware that can support it. We are still working through those details; currently the Node (N130), Node X (N131), Powernode (N330), and Powernode Edge (N230) are additional candidates for Dirac, pending certification..."
Thats awesome news! :D
I have had the Bluesound Powernode Edge, in my living room powernode Q Acoustics 3030is, with a sub out to a SVS Micro 3000. It's a lovely combo. BUT!!! The Pweronode Edge just randomly crashes, HARD, some days (like Memorial Day). I'll unplug it, wait a minute, plug it is, and then everything reboots. It's annoying, but not catostrophic. That said, the Powernode in our bedroom never crashes--and it gets run pretty hard as well. Not sure what is up with that, but it is annoying.
Make some contact here, first search, find others same problem, if no help put in a help request. They are pretty good about followup. Good luck
Thanks. I chased down the internet/wifi chain. It was the wired connection. For whatever reason, wifi is more stable, which makes no sense. I think the "puck" is defective.
Looking for an HDMI-CEC amp to stick behind a TV this is one candidate. But seems disadvantaged vs WiiM Amp EXCEPT for Dirac possibility. How much is the license(s) for this?
It's official. Dirac Live is now available on the POWERNODE EDGE (N230), and also the POWERNODE (N330).
Got the license for the N330 on monday, and running through the process worked like a charm. Got the full license, but ended up only correcting the lower frequencies after some testing.
Even though I already did room correction with REW and EQ APO, it’s nice to finally have everything handled by the amp - and on all sources.
