Try without the external dac to eliminate it as a source.
Doesn't the fact that the distortion goes away when I turn off "output level fixed" on the node mean that the problem is in the Node?Try without the external dac to eliminate it as a source.
Probably but one never knows in might be some interaction between the two. I suggested a simple test, it's what I would do. Look here also. Good luckDoesn't the fact that the distortion goes away when I turn off "output level fixed" on the node mean that the problem is in the Node?
Thank you, Tim. I'll try it out. I'm using the DAC in my Denon receiver.Probably but one never knows in might be some interaction between the two. I suggested a simple test, it's what I would do. Look here also. Good luck
Confirm that. I have an E30 in DAC mode (fixed output) and I can still control volume in the BluOS app in Android / Windows. Additionally, I bumped into a thread in the BluOS support forums with dozens of people reporting the are able to control volume when outputting to external DACs via USB.Absolutely not true, notwithstanding what the BluOS people say. I use USB out to my Topping D30Pro, and I retain volume control capabilities at every stage, whether TV (HDMI eARC into Node) or Node native streamer managed by the BluOS app run via Android.
Tim. You are a genius. I connected a DAC and the crackling went away. Maybe something is wrong with the digital inputs on my receiver or the output from the Node is too high. I did it that way to keep from going DAC>ADC>DAC. The Denon has ADC>DAC for the Sub out and Audyssey. I'm glad I posted and listened to you. Thanks.Probably but one never knows in might be some interaction between the two. I suggested a simple test, it's what I would do. Look here also. Good luck
Is the Denon old or do you live by the ocean, like me, could be dirt or corrosion. If so, buy a can a can Caig DeOxit D5 then unplug the AVR, clean all connectors, and into knobs and switches. Instructions on Caig website. Not genius just a veteran of these type things.Tim. You are a genius. I connected a DAC and the crackling went away. Maybe something is wrong with the digital inputs on my receiver or the output from the Node is too high. I did it that way to keep from going DAC>ADC>DAC. The Denon has ADC>DAC for the Sub out and Audyssey. I'm glad I posted and listened to you. Thanks.
I really need to do that. It's been in a cabinet for 5 years. Thanks for the suggestion.Is the Denon old or do you live by the ocean, like me, could be dirt or corrosion. If so, buy a can a can Caig DeOxit D5 then unplug the AVR, clean all connectors, and into knobs and switches. Instructions on Caig website. Not genius just a veteran of these type things.
I wonder if it might be that volume control on the node is only supported if the DAC doesn't have MQA for some reason. Or maybe it allows volume control if the DAC is in fixed output mode but I wonder how it even knows. Anyway, I'll do some more experimentingConfirm that. I have an E30 in DAC mode (fixed output) and I can still control volume in the BluOS app in Android / Windows. Additionally, I bumped into a thread in the BluOS support forums with dozens of people reporting the are able to control volume when outputting to external DACs via USB.
Whether it's related to MQA I can't say - I'm more inclined to think it's the DAC's preamp feature that causes this behaviour. Intuitively you would think that setting the DAC to fixed mode would render the volume control on the Node unavailable, but it in reality it does not make any difference.I wonder if it might be that volume control on the node is only supported if the DAC doesn't have MQA for some reason. Or maybe it allows volume control if the DAC is in fixed output mode but I wonder how it even knows. Anyway, I'll do some more experimenting
I'm using the Node in the same manner as well. Digital out to digital in on my Neumann speakers.Disappointing results. I am a happy owner of the Node 2i and the app is great in my opinion. I use this with two Bluesound Flex speakers in other rooms and they are also nice. DAC performance doesn't matter in my case, since I am using the coax output to feed a pair of Genelec 8340 digitally.
If you have a MQA DAC and want to decode MQA then volume cannot be done before (in Bluesound) the decode takes place (in the DAC)Whether it's related to MQA I can't say - I'm more inclined to think it's the DAC's preamp feature that causes this behaviour. Intuitively you would think that setting the DAC to fixed mode would render the volume control on the Node unavailable, but it in reality it does not make any difference.
Someone explained it could be the DAC's input/output controller (XMOS) that is reporting variable volume capability to the Node regardless of which mode you set on the DAC. Also, when I had the E30 connected to an RPi with Volumio the latter too was able to control volume.
Digital volume attenuation is not lossless. That's not to say it is problematic, but it isn't a completely lossless process to be specific.With digital out to digital in there is no need to change the signal and performance would be '100% correct' by definition right?
Have you tried turning off the “clock trim“ button on the Node?I'm getting crackling on some tracks with the Bluesound Node 2, but only when it's set on "output level fixed". Turn this off and the distortion goes away. And it doesn't matter what the volume setting on the Node is. It can be 100%. I'm not using the internal DAC and the distortion is there whether I use coax or toslink. Does anyone have any idea what's going on?
I'll give it a try. ThanksHave you tried turning off the “clock trim“ button on the Node?
I got distortion on some songs when I had replay-gain enabled. Interesting to know that the volume can still be controlled as I experienced difference in sound quality between USB and coax so maybe the volume setting is the culprit as well.I'm getting crackling on some tracks with the Bluesound Node 2, but only when it's set on "output level fixed". Turn this off and the distortion goes away. And it doesn't matter what the volume setting on the Node is. It can be 100%. I'm not using the internal DAC and the distortion is there whether I use coax or toslink. Does anyone have any idea what's going on?
