See if you can reflash?Very strange. I have tried with different dacs. Much better sound from spdif. Tried a lot.
Friends are saying the same, and I read that others have same experiences as mine.
Thanks, but I do not know how to do….See if you can reflash?
Hey Node users, a question: I want to use a tablet or laptop to control my Node. In this case, "control" mainly means searching Qobuz (or other streaming service), and starting / pausing / stopping the music. Searching is primarily for classical music, some rock and jazz, so a keyboard would be nice but I could handle a really good virtual (touch) keyboard interface if it really is easy and responsive.
Obviously the tablet/laptop needs to run the BluOS controller app. I *think* that I can use any of 1) Apple iPad (I'm not an Apple guy, so unsure if all the models would work), 2) a Chromebook capable of running Android apps, or 3) a Windows laptop. (I've used an Android phone, but the tiny screen is a pain for music searching.)
This same device will use a web-based app to control a preamp/processor; anything that can run web apps will work there. I'll also sometimes have the Qobuz web app open to read more about an album that I'm looking for, but the music will be streaming through the Node.
Any suggestions or experiences as to which might be best? Perfectly willing to go with a used device to save some bucks, but I don't need the cheapest choice, just one that will operate smoothly, easily, and reliably.
I repurposed an old Samsung Galaxy Tab S 8.4 and currently use it as my desktop BluOS controller/remote. Love the screen size and form factor of that tablet and it has given the 7-8 year old tablet some new life (BluOS is probably the only app on it and is permanently "pinned" on the screen). Have also used an old iPad (first one with retina display), and my many Android phones. Also have a newer Samsung Galaxy Tab S7 FE but find myself using BluOS on my smaller tablet or phones more often than not. You can really use your device of choice and I think you will be fine. No need to buy a fancy tablet just for this. Anything that can run your web apps should be fine I think. I did find that I prefer using Android over the Windows BluOS app (simple touch screen instead of switching to the app and using a mouse on Windows and better form factor) but I haven't tried the Windows app in at least a year. Now if you are looking for an excuse to buy a shiny new tablet or laptop and this will help further such cause then that is a different story...Hey Node users, a question: I want to use a tablet or laptop to control my Node. In this case, "control" mainly means searching Qobuz (or other streaming service), and starting / pausing / stopping the music. Searching is primarily for classical music, some rock and jazz, so a keyboard would be nice but I could handle a really good virtual (touch) keyboard interface if it really is easy and responsive.
Be wary of using an older tablet-2 of mine won't work with the BluOS app anymore. Once they're a certain age some apps aren't supported.Hey Node users, a question: I want to use a tablet or laptop to control my Node. In this case, "control" mainly means searching Qobuz (or other streaming service), and starting / pausing / stopping the music. Searching is primarily for classical music, some rock and jazz, so a keyboard would be nice but I could handle a really good virtual (touch) keyboard interface if it really is easy and responsive.
It was promised and didn’t happen for a long time.USB output is working with my denafrips ares2. It seems to sound better with the usb than coaxial connection. Would just like to know what is all this anticipation for this usb firmware update about?
Just tried my old iPad 3 which can only run up to iOS 9.3.6 and it did not work. Might need to run iOS 10 or newer?Be wary of using an older tablet-2 of mine won't work with the BluOS app anymore. Once they're a certain age some apps aren't supported.
Bluesound has acknowledged that the USB connection does not work with Roon presently.
I'm not unhappy with it, myself. But I understand it's mediocre.Many people would be happy with the DAC in the new Node... Just IMO
