Bluesound Node N132 USB-Audio-connection-with-an-external-DAC-fail
PolarisPrime
I am planning to return my bluesound node N132
Wanted to connect it through USB to my external DAC (N132->Topping D90III discrete-> A90 discrete)
I followed these steps, but did not work, no Sound.
So then it refers me to this page:
https://support1.bluesound.com/hc/e...SB-Audio-connection-with-an-external-DAC-fail
So does this mean I really need to install something on the N132?
That seems so weird to me for a 500 euro
Am I doing something wrong? Does anyone know why this happened?
Oh and yes, I am a noob. pls be kind :)
Before you give up (I've used USB DAC on an N130):
1. Power cycle the Bluesound device (Esp. if you used the USB earlier for a storage device).
2. Use toslink instead (from Bluesound to D90, presumably with no loss of transparency).
This way you can use the USB for stored music using a USB SSD or hard drive.
