This thread discusses the Bluesound Node Icon versus the WiiM Ultra a lot, but not really from a usability perspective. As someone who has used Bluesound products for nearly a decade and now owns a WiiM Ultra, I’d like to share my thoughts for people who are considering either device as the main “hub” for powered speakers or a power amp. In daily use, it’s often the small things that make you fall in love with a product.
Remote Control
The Node does not come with a remote control by default. You can configure most IR remotes to work with it, but I’ve always found this solution unreliable and not particularly elegant.
The WiiM Ultra, on the other hand, includes an Apple TV–style remote that is genuinely enjoyable to use. It works over Bluetooth rather than IR, which makes it much more responsive and reliable.
Volume Control
Because of the remote limitations mentioned above, volume control on Bluesound devices can sometimes feel inconsistent. Volume adjustments may be too fast, too slow, or change in steps that feel unpredictable. The volume slider in the app can also be frustrating.
On the WiiM Ultra, volume control is far more refined. The remote adjusts volume reliably and in consistent increments. In the app, the slider changes volume in precise 1/100 steps regardless of where you tap, which avoids sudden jumps to dangerously high levels.
Source Selection
The Bluesound app is not particularly intuitive when it comes to source selection.
On the WiiM Ultra, source selection feels much more straightforward, whether you use the app, the remote, or the touchscreen.
Display
The Node has a larger display, but the actual text size is not much bigger than the text-only mode on the WiiM Ultra.
So unless you specifically care about larger album artwork, the smaller display on the WiiM Ultra is not really a disadvantage.
Personal Music Library
This is where the Bluesound really shines. It can index your music library and present it in a way that makes browsing, searching, and selecting music a genuinely pleasant experience.
The WiiM Ultra does not offer this kind of library management out of the box. However, it does support Squeezelite integration. This does require a NAS or another server device to handle the indexing, so setup is more involved.
Once configured, though, the result is superior to the Node’s implementation. You essentially create your own private Spotify-like ecosystem that works independently from the WiiM app itself. Just like Spotify Connect or TIDAL Connect, playback control happens through a web-app.
Room Correction
I haven’t used Dirac myself, but I do come from using ARC (Anthem Room Correction), so I have some experience with room correction systems. I found WiiM’s RoomFit to produce excellent results when paired with a UMIK-1 measurement microphone.
In terms of sound quality, both devices sound excellent to me. I honestly doubt I could reliably hear a difference in a blind A/B test.
As an extra bonus, the WiiM’s built-in phono preamp is surprisingly good, certainly better than the phono stages built into most turntables.
Cost in Europe
Bluesound Node Icon: approximately €1250 (device, Dirac license, and measurement microphone)
WiiM Ultra: approximately €450 (device plus UMIK-1 microphone)
I couldn't justify the Node at almost three times the price. The WiiM Ultra is a great piece of kit.
