mikematrix
- Joined
- Jan 10, 2023
- Messages
- 71
- Likes
- 45
don't forget the umik microphone for Dirac
I have an old Marantz AVR that came with a mic for Audyssey. I was hoping to use that.don't forget the umik microphone for Dirac
Bluesound sells the microphone for Dirac installation and it is quite a bit less than the UMIK 1.don't forget the umik microphone for Dirac
I’m definitely not a subject matter expert but if you’re using Dirac with a proper mic over an iPhone there should be a noticeable improvement. Keep in mind Dirac is an advanced tool and it’s not as straight forward as Room Perfect or Audessey. There are people who can help and filters that should be applied after proper measurements. Some of us are adept naturally at this and others (myself included) are not so choose wisely. Ask yourself if you will dive down the rabbit hole or seek out help from experts? If the answer is no to either then no, it will not be an improvement, but it can be if implemented properly. For proof look at all the NAD M33’s for sale because buyers didn’t want to “figure it out”.Hi all,
I’m using a WiiM Pro Plus ($220) with its basic iPhone mic room correction. I'm considering a Bluesound Node N130 for $350, plus $250 for Dirac Live (total ~$600).
Is it worth the upgrade? Will I hear a noticeable improvement with Dirac?
Also, given that the WiiM has a better DAC (AKM vs TI), is the Node really a sonic upgrade, or just different?
Yes. It's only via USB that you don't get the corrections.Does the Dirac on the N130 affect the digital output? I mean, if I load the Dirac filters into the N130, which is connected via coax to my AVR, will I still get the 2.0 room correction?
For asymmetric layout makes all the sense your recommendation! Have fun!For me, it's precisely the gain/delay that makes all the difference. My speakers completely disappear, and even if you close your eyes, it's impossible to locate them.
The voice comes out perfectly in the middle of the stage, with everything else all around it. It should also be said that I have one speaker a little further away than the other due to the room, and afterward, Dirac corrected this problem, so personally, I would never disable this option.
So... everyone does what they want, as long as it suits them.
Not yet: https://www.dirac.com/brands/bluesoundSo can Bluesound Powernode Edge run Dirac? If so, how much?
I doubt it will ever get Dirac as they will use it as an excuse to create and sell a new product.So can Bluesound Powernode Edge run Dirac? If so, how much?
As of a few days ago I got an email from Dirac with the information that Dirac live now can be used on more models, including Powernode EdgeI doubt it will ever get Dirac as they will use it as an excuse to create and sell a new product.
