BLUESOUND goes Dirac Live
The Dirac software, although tied to the device, operates "independently" as far as measuring, etc., so for measurement purposes, you can use any mike, with the caveat that the best results come from a calibrated mike with associated calibration file so Dirac knows how to "interpret" the frequency response, etc.
My question is - has anyone actually tried it yet (especially with the N130)?
Just because they say it's now capable, doesn't necessarily mean it works well.
I tried it today (with a umik-1). Works well as far as I can tell, there was not a single crash or strange software issue during calibration or afterwards. The only limitation that I saw is that Dirac doesn’t work on the USB out. I had to switch to optical to connect my E50 DAC instead and disconnect the USB (otherwise the N130 would always default to USB after power cycling). It sounds good AFAIK, though the volume needs to be cranked up 6dB or so when using Dirac.
I think I'll also take the plunge and buy an N130 and a Dirac. With the two on sale, it's the cheapest device with a streamer and a Dirac.
Do you have 5 memories with it?
There 5 or 6 slots for the calibration settings. Then, one can switch between them and no calibration in the audio settings of the app. There is a few seconds silence and the new filter is then applied. This all pretty neat I must say.
I kinda really want to get it but it is really not necessary with my current Genelec GLM speakers which I will not change for at least a year or so.
Thanks for the update. I have read about the volume thing whenever Dirac has been used in other devices. I'm not sure, but I THINK I recall that the consensus is that because the EQ is more "balanced" and "even" after equalization, many find the sound "depressed" because their in-room response prior to correction was emphasizing low and/or mid frequencies.
Thanks. I think that the 6db that I have to increase the volume is likely due the added headroom than any depressed feeling of lack of bass.
If the target curve is flat, Dirac will actually remove the bass, which is logical. This is why I personally prefer to follow the speaker curve at the beginning because I also like this "bass room".
True. The default target curve is ensuring that it is not flat and that there is some room gain. However, it does not work in my case as I've only the low-frequency Dirac version: the target curve flatten too early and there is a frequency dip 150 and 400Hz.
With a custom target curve, I was able to have a smoother transition:
And here is the corrected curves:
Yes, that's better.
You didn't take the full band because we can clearly see the tweeter/speaker cutoff frequency at 2-3 kHz.
You could correct that too ;)
Yes, that's better.
Yes, one could correct for that but that’s the infamous Bower & Wilkins BBC dip, it’s the speaker voicing. I kind of like it like that :rolleyes:
Dirac Live now available for N130 & N131.
Promo code: BLUE30
BluOS 4.8.22. Released April 15, 2025
• Dirac Live Ready support for the Bluesound NODE (Gen 3) & NODE X
• This release applies to the Bluesound NODE (Gen 3) & NODE X only
Offer ends April 30th!
On the older N130 model, does Dirac Live get applied when doing Digital Out via Optical? What about fixed volume mode?
Hello,
I want understand, do you know why the sound is low when I use Dirac?
I notice a significative difference ...
I Have N130 with full band...
Thank you!
Hello,
Thank you!
That gives headroom to allow processing without digital clipping.
Hello,
Okay, thanks for the quick reply ;)
It's not a problem in itself; just increase the volume for a sound calibrated to the context of my room
(in this case, my living room with large walls, a high ceiling, and large windows).
For a few weeks now, my ear has preferred the corrected sound.
I took the measurement in wide mode and 17 points with the Umik-1 microphone and obtained a curve.
Is it better to leave the resulting curve or choose a Harman or any other curve?
And one last question, if I may, is it better to leave the Delay/Gain enabled or disable it?
I'm only in a hi-fi/stereo setup, and I'm delighted that Dirac is obtained on the N130 :)
Thanks for your answers.
Hi all,
I’m using a WiiM Pro Plus ($220) with its basic iPhone mic room correction. I'm considering a Bluesound Node N130 for $350, plus $250 for Dirac Live (total ~$600).
Is it worth the upgrade? Will I hear a noticeable improvement with Dirac?
Also, given that the WiiM has a better DAC (AKM vs TI), is the Node really a sonic upgrade, or just different?
