I'm surprised that so many of you prefer A over B. The overall sound of "A" is less clear and a bit on the "murky" side, and the separation between the instruments in the mix is way worse than that of "B".
Even if we can't be sure if it's the different masters of the song we judge or if it truly is the different sounds of the turntables, it's still interesting to dig a little deeper into the analysis of the sound differences, so the following is the way I hear it...
- The sound clip starts with a kick drum, a snare drum, a hi-hat, and a tom. The tom and the kick drum don't sound as punchy in "A" as in "B" and it's also more clearly hear the difference in velocity between the hits of the drums. All the drums sound way more defined, and the reverb tails ring out more naturally in "B" while it sounds more dampened/muffled in "A".
- The guitar almost sounds as if it's out of tune in "A", it sounds wobbly compared to a more stable tone in "B".
- The vocal in "A" suffers in the same way as the drums, it sounds less refined, "bloomy", and a bit on the thick side.
- At the end of the sound sample, all the above problems in "A" are heard even more when the intensity goes up in the song, and here it's easy to hear that "B" has way better and more clearly heard separation between the sound objects in the mix (or maybe just better separation between left and right channel in the playback system).
These are the differences I hear and why I prefer the sound of sample "B" by a large margin. I'm surprised some of you don't hear the abovementioned faults in sample "A". I think you should listen again, and use a DAW or something where you can A/B the different sections of the sound files easily.
