- Joined
- Jan 27, 2019
- Messages
- 7,323
- Likes
- 12,276
Hey folks, I thought I'd post about a little blind test I did between my two current preamplifiers:
Benchmark LA4
vs.
Conrad Johnson Premier 16LS2 tube preamplifier.
People are familiar with the Benchmark LA4 I'm sure:
A brief bit of info on the CJ Premier 16LS:
I'm certainly not presenting this as worthy for publishing scientifically; just giving a little report of my own modest attempt to do a blind shoot-out of the two pre-amps. All comments welcome of course! It arises out of my own subjective impressions. I've always felt I preferred tube amplification, tube preamps as well, but after borrowing a friend's Bryston 4B3 power amp for a couple of months, comparing it (non-blinded) to my CJ Premier 12 tube monoblocks, I felt I was hearing some things I liked about the solid state amplification, even though I preferred the tube amps overall. So I thought I'd try my luck with some solid state preamplification and purchased a Benchmark LA4. I have been going back and forth between the LA4 and CJ preamp in my system and have had great results with the LA4 (details below), though when I put the CJ preamp in...dang!...hard to part with the qualities I perceive there.
On to the test.
I'd talked to Benchmark about running the CJ preamp through one of the LA4 inputs to be able to do quick switching between the LA4 driving my amps directly, vs the signal going through the CJ tubed preamp in the chain. I was told it would work fine: on their suggestion I ran my Benchmark DAC2L outputs to both the LA4 preamp and my CJ preamp, and then ran the outputs of the CJ preamp in to one of the inputs on the LA4. Then I set that LA4 input at unity gain ("0" fixed). Once I've selected the CJ input on the LA4, I adjust the volume via the CJ remote control to match the output of the LA4 on it's own (switching between inputs).
For quite a while I've used this just to switch between each preamp to listen for differences. The characteristic differences I heard seemed to mirror when I'd run the CJ directly in to the amp vs the LA4 directly in to the amp. That's been made for very easy comparisons over the past little while. But I wanted to finally do it "blinded."
I first watched Amirm's video on blind testing again, just to refresh my memory and get tips I may have forgotten.
METHOD:
Music streamed from Raspberry Pi Squeezebox server to Benchmark DAC2L.
Benchmark DAC2L XLR outputs to LA4 XLR input 2.
Benchmark DAC2L RCA outputs in to CJ Preamp.
CJ preamp output run to RCA analog input "4" of LA4.
Benchmark LA4 preamp run directly in to my Conrad Johnson Premier 12 tube monoblock amps (out to Thiel 2.7 speakers).
LEVEL MATCHING: I had borrowed a voltmeter from a friend to match the signal at the speaker terminals but it didn't seem to work right (I'll put that in a separate post). Therefore, I ended up first using both the dB pro app and the NIOSH SLM decibel measuring app, on my iPhone 13, positioned at the listening seat, using a 110Hz test tone. Using the LA4 and CJ separate volume controls I was able to get exactly the same decibel reading for both signals. Afterward I checked this again using a SCOSCHE spl1000 Decibel meter. It turned out the SCHOSCHE read the signals as louder than the iPhone reading, but nonetheless the relative decibel reading on the SCOSHE between the Benchmark and CJ signals was bang on, just like with the iphone reading. Subjectively the levels seemed indistinguishable. (As someone who adjusts volume levels minutely all day for my job in sound editing I have a good ear for minute differences...not that it makes me infallible of course).
My son was doing the switching between the LA4 inputs. We were doing 2 test runs of 15 trials. "Forced choice" method, so I was to write my guess as to whether it was the LA4 playing or the CJ. We had two pages with columns of numbers 1 - 15, one for my son for switching, one for me to write my guesses. My son used an on-line random number generator to create the switching pattern for the two trials, writing down "L" for when he was to switch to the LA4 direct, "C" for the CJ preamp input. I would write "L" or "C" for my guesses, on my page, and we'd compare after.
I deliberately put the LA4 direct signal on input 2, the CJ signal on input 4, to leave input 3 blank. That allowed my son to always first switch to the "blank/silent" input first before selecting the next input, so that there would be no "tell" in the switching for me. All the source/amplification is in a separate room down the hall from my listening room, so I couldn't see or hear anything he was doing. The only communication, once the tests began, was me yelling "switch" when I wanted him to switch.
Whew! Sorry, boring stuff but this is the type of forum where people may care about such details.
So the test was to see if I could discern which preamp I was listening to - the solid state LA4 or the CJ tube preamp in the chain.
RESULTS:
Trial 1: 15/15 correct.
Trial 2: 14/15 correct.
(On trial two I'd initially guessed wrong, but immediately recognized the differences again between the preamps once the switching continued).
Benchmark LA4
vs.
Benchmark LA4 Line Amplifier
The award-winning Benchmark LA4 may be the most transparent line-level preamplifier available at any price. The 100% analog signal path features a pair of fully-balanced relay-controlled attenuators with 256 steps and 0.5 dB resolution. Designed, assembled, and tested in the USA using USA and...
benchmarkmedia.com
On to the test.
METHOD:
RESULTS:
