Blind Listening Test 2: Neumann KH 80 vs JBL 305p MkII vs Edifier R1280T vs RCF Arya Pro5
The dip around 2 kHz is something that I, @Thomas_A, and many others have discussed a lot at the Swedish forum Faktiskt, and even if it's a little step outside the topic of the thread, I like to take the opportunity to ask you one question about it if you don't mind.
With modern multi-mono recordings nowadays, it's common that every single sound element in the mix is equalized individually until they sound exactly the way the mixing engineer wants them to sound while monitoring the mix on a pair of loudspeakers set up in a regular stereo configuration (which of course should reveal the problem in the same way as any other stereo setup should be able to do). Isn't it then a pretty big chance that the dip at 2 kHz is (almost automatically) taken care of if this flaw is obvious and sounds audible wrong?
I mean, the mixing engineer doesn't even need to know why this particular stereo flaw occurs, if it's an obvious audible problem he should clearly hear it and try to fix it among all the other things he already equalizes in the mix. I do understand why this stereo flaw can never be addressed in the speakers themself because that would also affect the hard-panned sound, not just the phantom sounds in the mix. But do you see any reason why this particular dip can't be addressed in the mix itself, and just for the phantom sounds that are affected by it?
The 2 kHz dip exists only at the prime listening location, the sweet spot where all phantom images should be in their correct locations. Move away from that position, even a few inches, and it disappears, replaced by a mess of acoustical interference that is different for every location. So, if the recording engineer decides to fill the dip with EQ, he is adding a "resonant" bump in the frequency response for all other listening locations. Is this a good idea? In addition there is the consideration that EQ is a minimum-phase solution for a non-minimum phase (acoustical interference) problem. The problem is stereo itself - it is fundamentally flawed, but we have largely adapted to it's flaws. Sadly there is no choice.
This dip has been discussed many times at ASR and while there is little to do about, the problem seems to be less in a reflective environment than in near-field or anechoic conditions. I am a bit perplexed though as whether reflections should matter since it is the direct/first arriving sound that matter for how we hear "frequency response", while reflections add to the ambiance.
So is the problem equally big regardless of acoustic environment? Or do the reflections aid to fill in the errors? I can't really get it together.
Obviously, reflected sounds assist in filling the dip, but they come after the direct sound that causes it, so-o-o-o. Figure 7.2 in the 3rd edition shows one result of measurement in a reflective space. A definitive answer requires controlled experiments that I do not know have been done. I'm retired - anybody interested?
Meanwhile I will continue to enjoy the music, mostly in my upmixed multichannel system. Compromised? To be sure, but very enjoyable. We have no choice.
I have always assumed that's why I find listening to "centered vocals" in mixed rock/pop tracks much more satisfying on good headphones, versus trying to move my head back and forth at the MLP trying to get that same vocal to "snap into focus." It's one of those things that once you hear it, you can't unhear it.
Yes, indeed. It is interesting to realize that the "Ideal" method of record/reproduction is binaural (dummy head) recordings replayed using insert earphones. The recording captures a close approximation to the sounds that the ears need to hear, and the substantial unknown for an insert earphone is the short length of ear canal before the eardrum. It is so simple. But, without head movement tracking getting the sound to convincingly externalize is the problem. I have experienced it and it is phenomenal.
With wireless being so good these days, even wearing headphones is less of a bother. Ideal, maybe, but very difficult to popularize. Gaming may be the entry point.
Meanwhile we make do with loudspeaker stereo with its ailments.
Yes, these would be interesting experiments.
(My research is a bit far from audio though and I passed the peak of publishing papers...so someone else...)
Yes, I'm aware of that, but I'm also sure that the mixing engineer is sitting in a prime listening position while making all other equalization decisions for the mix as well. So with that in mind, there should probably be a lot of other peaks and dips outside the prime listening position for most modern mixes anyway.
Isn't other stereo flaw there anyway if we step outside the prime listening position, so why not prioritize addressing this particular 2 kHz dip which will make it sound right at least in that small prime listening position?
Thanks. Our daughter has a degree in speech, language & hearing science while not an audiologist, learned to examine ears before a summer program in India. She knows that both of us have an somewhat unusual shape plus a kink in our ear canals. When I told her that I found deep insertion of Etymotic triple flanges very uncomfortable and never felt they were seated, she saw a picture of them and said I shouldn't even try. She flat out refuses to use IEMs herself and only uses headphones at low volumes.
the multimillion dollar investment that Harman International made for 17+ years - allowing the results to be published for our competitors to share. How many companies would do this? Altruism? Some, believe it or not, out of respect for the scientific tradition of sharing results, but also a realization that competently done research reflects well on the people involved and the brands associated with the sponsor. Sadly, a few people think it was just marketing. Sigh . . .
Dr Sidney Harman was a remarkable individual and a well-documented philanthropist. Like you suggest here, Floyd, he really deserves to be excused from the standard assumptions about corporate greed and motivation.
Cynics would normally be entitled to taint your time at Harman with accusations of bias, and have done so on numerous hifi forums, but I plead that they inform themselves of the individual at the helm of Harman International in those years, and grant an exception.
cheers
Not really. It really is a hot-seat-only issue, and should not be down-played or trivialised as one of many such issues. To my knowledge, 'other' peaks and dips are perceptually much less important.
Two reasons.
If the recording engineer tries to fix it in the mix for listeners at home on stereo loudspeakers, it will create an inverse problem for people using headphones. Let's face it, since the PC and smartphone driven explosion in headphone usage over the past 15 years or so, headphones are now the majority means of consuming stereo sound. It's too late for your idea.
Secondly, multichannel audio is here and fixes it. That's the way forward. Ideally listening to MCH mixes, but even upmixing 2-ch recordings to MCH at home can do much to alleviate it. Again, it's too late for your idea.
cheers
Just checked the JBL priced at $149 on Amazon. Lots of price differences right now between manufacturers.
Who first adjusted the price will be the winner in this economic recession. EU inflation vs US disinflation
Got a pair of 305's last year from Musicians Friend when it was "stupid deal of the day" $199. Hard to beat them at that price. Tried getting the matching sub from JBL when it was on-sale but the order got cancelled due to fulfillment issues. Instead I got a pair of Monoprice T6 towers during their march madness sale for $390 all-in. I hate using adjectives but the 305's have a crisper/sharper sound and the T6 have a much broader range digging down into the 30's.
Both are great budget options when on sale. YMMV
Anyway OP I estimate you are likley just happy to have people involved, beyond that what are your general interests here in terms of what population of people are you interested in gathering?
Neither my friend or I have set out on this with any expectation of actually contributing to the current science. It mostly comes from our own desire to learn more, and experience blind listening tests. If we can share what we are doing with the community and get more folks interested in evaluating speakers blind--all the better. For the next round, we're going to likely open it up to anyone in the "audiophile" community that wants to participate. If you come along with an audiogram and have training--all the better. But if you just want to experience a blind listening test, that's fine too.
As always, it is best to see an audiogram before putting faith in anyone's opinion about sound quality.
I actually have mine from last year! I'm 43 and felt it could have been better--but it seemed not terrible for someone that went to a LOT of rock concerts (I started wearing ear plugs as a teenager). The technician was a little surprised how much I could still hear at 20k.
Two reasons.
cheers
Too late? I don't think so. :)
I think it’s already unconsciously done half of the time a mixing engineer equalizes the vocal track while using speakers for the task. In today's modern mixing, usually, not a single track goes by without it being processed and sculptured severally by EQ and other tools. And if the 2 kHz dip is an obvious fault on such an important element as the vocals are, I have a hard time seeing that particular problem slipping under the radar, no matter if the mixing engineer knows or don't know why he wants to add some energy to that particular area on the vocal track.
T6 Tower is what I’m looking for: 4 Ohm impedance and 2 terminals (bi-wiring). Very nice, exactly freq response below 40 Hz. Thank you.
But it still needs measurements for the specs coformance
@goat76 ...but then every time the mixing engineer pans the sound away from centre, the sound goes sick.
And even if said engineer somehow dynamically adjusts the correction as the sound is panned, it is only right in the dead centre seat, and it is all wrong for headphones.
And most listeners are using headphones now.
That's why it is too late.
You are just making that up. I don't believe it at all, for all the reasons I have given. It just wouldn't make sense.
This isn't just "the 2 kHz dip". Firstly, it's 10 dB deep in an anechoic chamber.
So that's the direct sound contribution.
But then the in-room effects modify the difference, depending on how reflective is the listener's room. How reflective is your room? How reflective is the next guy's? How is the mastering engineer going to deal with that variation? And look at the appearance of variations at 3-5 kHz and 7-9 kHz...you want the sound engineer to account for the different amounts of that in different rooms?
But we're not done yet! Human perception somehow manages to distinguish between contributions from direct sound and from reflected sound. Either one being wrong is perceived as not-right. So which are you going to have the sound engineer correct with EQ?
No, it's a mess. Sound engineers are probably schooled to leave bad enough alone. I bet that's exactly what they do, thank goodness.
cheers
cheers
Meanwhile, you can try to figure out how many modern mixes you can find where to vocal is not in the center of the mix. :)
It’s not too late and it's nothing we have to wait for, it's not a new trend to use EQ on almost every single sound element in the mix. If the 2 kHz dip is not heard as a problem it's simply not a big problem. If it's heard as a problem it will most likely be addressed by the mixing engineer with EQ in the mix, if the he or she are using speakers while making the adjustments. It comes almost automatically with today's “mixing package”.
Thank you for the graphs, I think I maybe run some tests and create some recorded and mixed sound examples of this some time. That could be interesting.
cheers
Since that measurement, made in a standardised reflective room, do fill in the dip and cause other peaks in the 3-4 kHz and 8 kHz range, you can also argue that the 1-8 kHz range is a "fuzzy" range where there is room for subjective differences in evaluating speakers in stereo. The problem cannot be solved in the one-dimension (EQ on axis) but must focus on three dimensions (speaker dispersion). That makes is a complicated experiment to conduct and as Dr. Floyd Toole says, is someone willing to do it?
My take as I've done many times, speakers that exaggerate the pattern on/off-axis may sound harsh while speakers with inverted pattern sound smoother. Especially on female voices, sopranos, tenors etc. The 1-2 kHz "dip" is clearly audible to me, but its audibility can be reduced.
The in the EQ mix problem is not possible, since it is a cancellation issue caused by stereo. I think the only way to adress it is to reduce some energy above 2,5 kHz with EQ. The other solution is to make sure that your speakers do not amplify the problem, but rather aim to reduce it.
