Excellent point. With a -6db of 48Hz to hear a tone as low as was being played back the speaker and amp were working incredibly hard.Ported (and active) subwoofers normally have this feature. Active speakers will also typically have that and/or active limiters to prevent you from frying the drivers unless you REALLY try.
Passive speakers typically do not have high pass filters. A 10 second continuous sine wave below the port tuning is a very different scenario than normal music, and is what I would consider an active attempt to ruin the drivers. The driver will flap around uncontrollably, bottoming out, possibly tearing the suspension. To even be able to hear a 30hz (not to mention 20hz) sine wave from a speaker like that is a pretty safe sign you're playing way too loud.
I would prefer that manufactures didn't add more passive filters just to prevent people from destroying the speakers doing something they were never intended to do. A 20Hz signal as part of music would: not last as long as a test tone and not even be audible at most listening levels.I believe that if manufacturers don't implement a high pass filter, then I'm not responsible if the woofer smokes with 20 Hz signal, because not all audio devices have one.
I'm guessing the volume level and power that it required to make a decently loud 20Hz sound out of those speakers would have created a deafening 1000Hz sound. That is the 'safety' feature that audio devices have to warn you that the amp output it too high...... when playing music.
